Temperature Sending Unit
Old Mar 10, 2004 | 02:39 PM
Flood's Avatar
Flood
The temp guage in my 94 Ranger is stone cold, though I do get heat. Where is the location of the temperature sending unit?
Thanks.
Old Mar 15, 2004 | 08:50 PM
JoshsFord150's Avatar
JoshsFord150
i'm having a simular problem with my 96 Ford F150, staying dead cold. although its getting hot, the local garage here told me to replace the Coolant Censor, but I also cannot find it.
Old Mar 30, 2004 | 08:45 PM
fordtruckfan90's Avatar
fordtruckfan90
its on the thermostat housing
Old Mar 31, 2004 | 06:22 AM
Flood's Avatar
Flood
fordtruckfan90 ,
Thanks very much. That is where I suspected it might be located.
Old Mar 31, 2004 | 06:34 AM
Bob Ayers's Avatar
Bob Ayers
Depends on the engine, but it is normally close to the thermostat housing (maybe mounted on the intake). Becareful, though, there is also a ECT sensor close to it.
The gauge temp sensor will have a 1 wire connector, the ECT sensor will have a 2 wire connector...you want to replace the sensor with the 1 wire connector..
Old Apr 18, 2004 | 08:37 PM
Cool1996's Avatar
Cool1996
on the 302's it is behind the compressor by the distributor. plan at least 1 1/2 hrs to do it on a 302. to check your guage to make sure it is the sending unit, have someone sit in the truck with the key on (not running) and ground out the wire for the sending unit to the cylinder or something (you may need an aligator clip wire or something) and when you ground it out it should peg to hot. if it doesn't peg and probably if it does use a mechanical guage.don't hold it grounded for more than like 1 sec or the guage will smoke
cbquinn66
Apr 4, 2017 12:03 PM
regidog
Mar 19, 2017 04:56 PM
S.P.
Aug 27, 2016 11:27 AM
jerryparks
Aug 13, 2015 09:05 PM
beckman
Jul 10, 2014 11:39 PM
