289 heads
Old Mar 10, 2004 | 09:16 AM
faceman1's Avatar
faceman1
289 heads
hello everybody
well i have a quick question
a friend of mine wants to put 289 heads on his mustang 302. the heads are ported and polished with stainless steele valves. his mustang is i believe around a 92. what will this modification do for his horsepower?
is this a good idea or is he just wasting his time?
thanks in advance.
faceman
Old Mar 10, 2004 | 12:59 PM
jwtaylor's Avatar
jwtaylor
I would say it depends on what he's paying for them and how extensive the port work was.
Whats the casting number on the heads? (it can be found under the head, with the intake ports facing you, it will be to the lower right, and should start with a "C")
There are some variations on these heads, some have smaller combustion chambers and would increase compression, some have the same size chamber and wouldn't be much of a benefit. Some have similar ports as the E7's he has, some are a little better, I guess the ports really depend on who did the port work and how much.
later
Old Mar 10, 2004 | 01:03 PM
faceman1's Avatar
faceman1
thanks jw
as a side note do you know if the heads he has currently on his 5.0 are the same that i would have on my 91 f150 with a 5.0
i am just a little curious.
thanks again
faceman
Old Mar 10, 2004 | 01:14 PM
jwtaylor's Avatar
jwtaylor
should be.
55F250
Sep 9, 2015 07:58 PM
dogstar
21
Nov 11, 2010 12:39 PM
rmalottwtes30
Oct 28, 2006 01:16 PM
roger dowty
May 7, 2006 02:52 AM
mauicruza
Oct 6, 2005 08:50 AM
