289 hi-po heads c5ae update
Got some info:
There are two good heads for the 289 with the c5ae# :
If there is an 'HP' designation stamped on the head it is the high performance head. If not its the 289 4V head with the same compression chamber. Put 3/8" studs and bigger valves and it's the same as the hi-po.
had a mustang show in town and i asked a few in the know....? I'm assuming the HP stamped heads are gold and the 4v silver regarding value...neither bad.
on
One good way to tell the diff is that the Hi-po heads had machined valve spring seats to prevent the spring from walking in addition to screw-in studs (which can be easily added to non-hi-po heads.)
I once had a set, didn't really know the value of them and sold them to a buddy for 200 bucks...
SlikWillie
05-13-2016 09:10 PM
father/son
17
12-15-2011 06:18 PM
hooler1
23
09-03-2011 10:42 PM
