9" ford track lock
Old Mar 9, 2004 | 09:57 PM
chucks blazer's Avatar
chucks blazer
9" ford track lock
i need to find out how tight to set up the clutches in a track lock rear in a 79 f 150 i have the new clutches instaled and would like to know how much torque it should take to spin one axel.
Old Mar 10, 2004 | 05:00 AM
RTM's Avatar
RTM
If I recall it is around 200 ft lbs or more. I can try to look it up later today if need be. I just shimmed my buddy's up and when he turns a corner it acts like a spool. That puppy is tight.
Old Mar 10, 2004 | 11:47 AM
chucks blazer
Thanks RTM i just installed the new clutches and didnt know how tight it should be i think i will have to put in more shims .It had 10 thousandths in it from the factory and i replaced that with 20 but it still only takes about 50lbs. to turn 1 axel. I think i will add 5 more and try that. I just didnt want to get it too tight
Old Mar 10, 2004 | 03:02 PM
RTM's Avatar
RTM
Just make sure that the cover is not held up when you shim it. The cover should bottom out on it's own not the clutches. I would go for another .010 shim if it only takes 50ftlbs to turn it.
Old Mar 11, 2004 | 09:08 PM
chucks blazer
well i got it back together and it was to tight it wouldnt hardly slip around curves so i took it back apart and put the stock shims back in. it is better but i chatters real bad when you go around a curve.i think i will add another tube of additive and see if that helps if not i may just drive it for a while.
Old Mar 12, 2004 | 04:42 AM
RTM's Avatar
RTM
You may just need to give the oil some time to get into the cltuches. Go to a parking lot and drive in circles to help lube the cltuches.
Old Mar 12, 2004 | 02:26 PM
red_rocket's Avatar
red_rocket
as tight as possible, also don't use any addative, unless it's chattering really bad around corners.
Old Mar 13, 2004 | 01:30 AM
chucks blazer
i just added the second bottle of additive today and it helped it but it is still chattering around corners at slow speeds. i think it is getting better as i drive it. it was so bad it would shake the whole truck.
J2H
17
Jul 7, 2024 07:48 PM
Mr J 125
Mar 27, 2022 10:47 AM
hasteranger
Jan 9, 2017 05:52 PM
Chuck Fuller
Mar 26, 2015 04:47 PM
OldStroker
Aug 23, 2010 10:18 AM
