Fuel Pres Regulator Question??
Old Mar 9, 2004 | 06:10 PM
geowolf's Avatar
geowolf
Exclamation Fuel Pres Regulator Question??
OK, ON A 88-92 FORD 2.9L FUEL INJECTED MOTOR. AND 2 FUEL LINES FROM THE GAS TANK. DOES THE FEED GOTO THE REGULATOR OR TO THE RAIL DIRECTLY. problem i am currently having is with the feed hooked upto the regulator it will not run. with the fuel to the rail it runs ok but not right and loads up too bad with gas. and help?????
Old Mar 9, 2004 | 06:14 PM
Bob Ayers's Avatar
Bob Ayers
The feed goes to the rail, and the return line goes to the regulator. You might want to pull the vacuum line off the regulator and see if you find gas. Applying high pressure to the regulator may have damaged it....
Old Mar 9, 2004 | 06:58 PM
geowolf's Avatar
geowolf
there is no gas in the line at all. all the plugs foul fast and the thing runs like crap.
Old Mar 9, 2004 | 07:04 PM
Bob Ayers's Avatar
Bob Ayers
Have you checked the fuel pressure at the schrader valve????
Old Mar 9, 2004 | 07:11 PM
geowolf's Avatar
geowolf
not as of yet. thats about the only type of guage i do not own.
Old Mar 9, 2004 | 07:21 PM
Ken00's Avatar
Ken00
The other line is a return, if its clogged you will have very high fuel pressure.
Old Mar 10, 2004 | 11:06 AM
geowolf's Avatar
geowolf
is not clogged in fact it has a vacume but the regulator does not push any out. the only way the fuel gets back to the tank is from the suction getting created in the tank from the pump
Old Mar 10, 2004 | 02:39 PM
geowolf's Avatar
geowolf
update.... new regulator installed today. this one spits fuel so it must help a little. got the timing set " I THINK" with spout pulled set at 10 deg befor "as per manual" and with spout in it jumps to 20 befor . i hope this is normal. anyway, no difference in the way it runs. seems to be a never ending story.
Old Mar 10, 2004 | 07:25 PM
Ken00's Avatar
Ken00
That change in timing is normal, my 1989 moved farther but then the programing may have been different.
