1978 - 1996 Big Bronco
Stalling at stop
Old Mar 9, 2004 | 04:59 PM
RichVollberg's Avatar
RichVollberg
Question Stalling at stop
I have a 89 bronco with the 5.0 EFI. I dont have a check light on but i did a code test just to see, the only thing that i can get to come up is a koeo code of 67 no other tests work as far as continous codes. The idle rpm is fluctuaing from about 480 to 600rpm with an average staying around 550 or just below in neutral. This seems low to me. Ive replaced the O2 sensor, Plugs, wires, coil, Ign module in the distributor, Cap and rotor. Im at a Loss 6 months ago i did replace the low pressure pump in the tank. And the ign module died a few weeks ago but this was going on before that. Any idea's on what to check, without codes im at a loss as to what part to look at next. P.S. all vacume lines apear to be in good shape so I dont think its a vacume leak.
Rich Vollberg
Old Mar 9, 2004 | 05:08 PM
Jdenninger's Avatar
Jdenninger
Check your TPS. the idle speed is too low. check this thread:
https://www.ford-trucks.com/forums/s...2B%25252Bspeed
Old Mar 9, 2004 | 07:44 PM
aglpml's Avatar
aglpml
try the idle air valve. Mine was idling at 2500 rpm and the TPS voltage checked good (easy to do with a digital multimeter).
I can e-mail you a picture of how I checked mine
Old Mar 9, 2004 | 07:53 PM
RichVollberg
TPS is now top of the must check list. Thanks for the info. Mines a 89 eddie bauer by the way.
Red with Tan.
Old Mar 9, 2004 | 07:59 PM
aglpml's Avatar
aglpml
I uploaded pictures in my gallery of the TPS and idle air valve
Old Mar 9, 2004 | 09:05 PM
RichVollberg
thanks for the help good shots to. Im off to the parts store tomarrow.
Old Mar 9, 2004 | 09:23 PM
Mary_Kate_Olsen's Avatar
Mary_Kate_Olsen
I had a low idle & stalling and stop problem. Traced it to the EGR valve getting stuck open intermittenly. Try cleaning yours out with throttle body cleaner.
Or to check to soo if the EGR is the problem you can use the dime in the EGR tube trick to permantly close the EGR valve. If your idle should increases when you do this then you found the problem.
RebusCom
55
Jan 26, 2023 11:45 AM
Xtreasurehunter
15
Mar 11, 2006 10:00 PM
noFordguy
Feb 28, 2005 09:41 PM
vincejr
Oct 24, 2003 04:45 AM
b1rdjx88
May 13, 2000 09:48 PM
