Bad NEW rotor?????
Old Mar 8, 2004 | 08:19 PM
easpilman's Avatar
easpilman
Bad NEW rotor?????
Just got new rotors and pads. Put them both on and took it for a test drive. Shaking all over the place. Took one rotor off and put an old one back on, still shaking. Took the other off and put the other old one back on and it's fine. End result, new pads old rotors, no shake. I'm guessing the last rotor I took off is warped out of the box. Any way to tell before I take it back???
Thanks for the help
Eric
Old Mar 9, 2004 | 12:07 AM
buzzard's Avatar
buzzard
Got a lathe? Probably not. A perfectly flat surface would allow you to check one side, but if they are as bad as it sounds, you might be able to "eyeball" it. Take it (them) back anyway. The parts store shouldn't give you any grief. They'll just send it back to the manufacturer.
Old Mar 9, 2004 | 08:07 AM
easpilman's Avatar
easpilman
I couldn't tell by eyeballing it. I layed a level on it but nothing seemed out of place.
I was just wondering if anyone else has ever had a problem.
Thanks
Eric
Old Mar 9, 2004 | 11:30 AM
tsdrallyer's Avatar
tsdrallyer
What brand was the new rotor? What brand and type was the new pad? Did you use a torque wrench to torque the lug bolts on the wheels after installation? Did you renew the lube on the caliper slides? Do you have a micrometer to measure roor thickness all the way around the pad contact area? Did you put ant-isieze on the shaft when mounting the new rotor?
Old Mar 9, 2004 | 01:04 PM
easpilman's Avatar
easpilman
I have no idea of the rotor brand. The pads are wagner. Yes, torqued the wheels....no didn't renew lube on caliper slides.....yes I have a micrometer and yes I put anti-sieze on. I don't think the lube had any bearing on the issue though since I was able to put the old rotor back on with good results.
Old Mar 9, 2004 | 01:14 PM
t0ny78's Avatar
t0ny78
yes even new rotors out of the box can be warped and require to be cut. if you have a micrometer you can measure a couple diffrent spots and see. also you might want to check your calipers this would also will eventually lead to the same problem of the shaking if the are sticking or froze.
Old Mar 9, 2004 | 01:22 PM
tsdrallyer's Avatar
tsdrallyer
The reason for the lube question was binding between parts can cause incorrect alignment, even when torqued properly.
No new lube on the caliper slides can cause them to not contact squarely with the surface of the rotor, that can cause "skipping" or "hopping" of the pad on the disk, with either squeal, shaking or excessive uneven disk and pad wear, but it only occcurs while braking.
beyond this, I have no idea other than your first suppostion: bad rotor. I've heard local parts men (those not on commission sales) say that many rotors shipped from the far east are not good products. Maybe you have one. It you can take it back where yoiu got it. If not, take it to a machine shop and have it checked for roundness, weight, alighment and thickness. It could be that it was not ground to have parallel ffront and back surfaces, so there is a thick (heavy) edge and a thin (lighter) edge.
Hope this helps.
Old Mar 9, 2004 | 01:35 PM
Sturge's Avatar
Sturge
Best way to check is with rotors still on and spin them while checking runout using a dial indicator. Sometimes the problem is not the rotor itself but the way it's mounted to the hub. You can check this by 'clocking' the rotor (pull off, partially rotate and re-install with different holes lined up to different studs). This is why many recommend matchmarking the rotor to the hub prior to taking off and bringing to a shop for turning of rotor. By doing this you can reinstall in the exact same position it came off...at least that's the idea!
Old Mar 9, 2004 | 02:41 PM
buzzard's Avatar
buzzard
I'm pretty sure I remember reading that these are not supposed to be serviced per my shop manual. FWIW, it also says not to clean the TB.
Old Mar 10, 2004 | 08:12 AM
easpilman's Avatar
easpilman
Sturge, that's a great idea. Can't believe I didn't think of that. By the way, I checked a few spots with my micrometer, no difference. I'll then runout and if that's not it, I'll just grab a new caliper.
Thanks to all.
Eric
Old Mar 10, 2004 | 12:48 PM
FarmLaw's Avatar
FarmLaw
Not at all uncommon to see 'new' rotors be warped. The shop I used to work at would always stick rotors on the lathe and check them for trueness prior to installation. When I asked someone from the rotor manufacturer about this, I was told that, especially with rotors shipped with studs installed, the rotors near the bottom of the pile can have a lot of weight on them, spread very unevenly, and even if the rotors are made true, they can be bent in transit. I think that's a crock...but...I've seen a lot of new rotors that were untrue.
Old Mar 10, 2004 | 02:59 PM
easpilman's Avatar
easpilman
The rotor is fine and the dial indicator didn't fluctuate enough to cause my problem. Any other suggestions other than to go buy a new caliper?
Thanks again for all the help.
Old Mar 10, 2004 | 03:22 PM
Sturge's Avatar
Sturge
Well...at least you have eliminated the rotor as the problem and didn't end up chasing that wild goose!! Not sure what I would do next but I do know that calipers are not cheap...I guess I would take the time to remove caliper, inspect fasteners, clean all mating surfaces and lubricate properly. Maybe that will do the trick and save you some $$? Any idea what a caliper goes for?
Old Mar 11, 2004 | 07:45 AM
easpilman's Avatar
easpilman
I am going to try and lubricate it, if that doesn't work I will be getting a new caliper. I'll let you know!
