Sponsored by: Kumho
Extended Brake Lines
Old Mar 8, 2004 | 06:30 PM
xbronco94's Avatar
xbronco94
Might be a stupid question, but I have a '94 Bronco that I'd like to put a 2", maybe 3" body lift on to clear 35's/36's. I already have a 4" Suspension lift on it with the stock brake lines. In order to accomodate the 6-7" of total lift will I have to replace the stock lines with extended break lines? Also, if anyone has experience with body lifts, how difficult would it be for a couple weekend mechanics to install one of these things. Thanks for the help.
Brad
Old Mar 9, 2004 | 02:51 PM
RawPower's Avatar
RawPower
Yeah you probably will, and if not, probably should. When you flex and stuff you could rip em out of there...
Old Mar 9, 2004 | 10:08 PM
MustangGT221's Avatar
MustangGT221
Well the rubber hose is mounted to the frame which doesn't move when you lift the body. The only thing to watch out for is the metal lines but those should be fine too.
David Fehir
Feb 8, 2016 09:19 PM
tyler.dunn94
Jun 27, 2015 10:14 AM
MBBFord
1978 - 1996 Big Bronco
Oct 18, 2005 07:41 PM
84 Diesel
Offroad & 4x4
Feb 6, 2005 08:19 PM
montster
Jul 29, 2003 03:49 PM
