1978 - 1996 Big Bronco
Fuel filter (s)??
Old 03-08-2004, 06:13 PM
Broncobirdy's Avatar
Broncobirdy
Broncobirdy is offline
Fuel filter (s)??
Are there more than the main one that is bolted on the inside frame on the drivers side? Mine is a 93 5.0L
Old 03-08-2004, 08:13 PM
Roger Carter's Avatar
Roger Carter
Roger Carter is offline
I cannot speak to a 93 rig but I do know that on an late 86 full size, 5.0L with EFI, there are two fuel filters. The "second" filter is in the "usual" spot, under the driver's floor, attached to the inside of the frame rair. The "first" filter is tucked above the transfer case crossmember, attached to the driver's side frame rail. This one is hard to see and harder to replace.
Roger Carter
Old 03-08-2004, 11:53 PM
bigric's Avatar
bigric
bigric is offline
'93 only has the one filter along the frame rail. Earlier models had two.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Fuel filter (s)??
