Hitch reciever vs. Bumper
Old Mar 8, 2004 | 07:09 AM
bri's Avatar
bri
I got an F350 a couple months ago. I have wanted to tow a couple of things so far. However the ball on my bundy bumper is pretty high up and at least in the case of my fathers little tent camper it is too high.
What are my options? I assume 2.5" receiver hitch is the best.
Is anything towable from the bumper? It does seem pretty high.
Thanks,
Brian
Old Mar 8, 2004 | 08:19 AM
johnsdiesel's Avatar
johnsdiesel
Anything you tow should be level. I would recommend a frame mounted receiver, but class V hitches are not necessary in most cases. A 2" receiver (Class III or IV) should be plenty.
Old Mar 8, 2004 | 06:58 PM
Lou Braun's Avatar
Lou Braun
I'd recommend that you get a quality heavy-duty frame mounted hitch. Installing the hitch will take an afternoon and when you are finished, you will be able to tow anything that you might want to.
One of the advantages of having an F-350 is its ability to pull just about anything that can be moved. Might as well set your truck up to use it's capabilities.
Once the hitch is installed, you can use a drawbar with the proper drop to match what you are towing.
Lou Braun
Old Mar 10, 2004 | 09:31 AM
bri's Avatar
bri
That is the conclusion I came to Lou. Took about 3 telephone calls to trailer shops in the area.
I found a class V 12k hitch by sure pull for $250 installed, will get it done today.
SMLWinds
Jan 26, 2015 07:58 AM
Brian 2002
Dec 11, 2014 04:38 PM
fishmanndotcom
All Things Towing
19
Oct 21, 2004 11:59 PM
BlueMeanie
Appearance & Dress-Up
Dec 2, 2002 11:48 AM
