351M to 360
Old Mar 7, 2004 | 11:30 PM
glen-ford's Avatar
glen-ford
351M to 360
1 have a 77 f250 3/4 ton 4x4 with a 351m and a 72 f250 3/4 ton 4x2 with a 360 Both trucks have 4 speeds Will the 360 bolt in on the 351 frame mounts Will the 360 oil pan fit in a 4x4 Will the bellhousing work any info would be helpful
Old Mar 8, 2004 | 09:50 AM
Mike G's Avatar
Mike G
You will need to use the engine perches from the 72, as well as the tranny crossmember and the bell housing. Nothing will swap between the 351m and the 360. You should also invest in a 4x4 oil pan (rear sump) for the 360 as you may starve the engine if hill climbing...
--Mike
Old Mar 11, 2004 | 01:59 AM
mark a.'s Avatar
mark a.
From one slug to another
38-55wcf
Jan 29, 2012 07:41 PM
rebelrebel
Apr 28, 2011 11:31 PM
Econoline 150
23
May 31, 2010 11:05 PM
Rancho*Ryda
Engine Swaps
Jan 9, 2005 11:45 PM
dino360
Oct 30, 2004 09:51 PM
