trasmission problem leak
Old Mar 7, 2004 | 01:57 PM
AdiDcn's Avatar
AdiDcn
hi this is a 95 4.0l V6 and the tranny leaks i thnk between the engine and trans right there were the stik together ....
here is the story all started with 628 code....i took it to the trans shop was there 2 months and finaly they fix it afther 3 times theyy took it out now started to leak and also i seen a hole made with a dril not too big but is not suppose to be there is close to the area were leaks i belive the trans shop did that to kill my trans in time....
i dont know but is there any liquid between the trans and engine? were are the flywel and cluch all that? how u put liquid there?
Old Mar 7, 2004 | 05:13 PM
Opera House Works's Avatar
Opera House Works
The torque converter is located between the engine and the transmission. Thr torque converter is a sealed unit but it can get cracks and leak. The most likely problem is a leaking seal between the transmission and rotating torque converter. This seal usually does not have any pressure on it. When it leaks, it is usually because other internal bushings are leaking because they are worn from a poor alignment. This transmission has been out several times. They may have solved the first problem, but they have created a new problem because of poor assembly practice. Just replacing the seal will not solve the problem.
Old Mar 8, 2004 | 07:29 AM
jwirth's Avatar
jwirth
I have a '94 with the same leak. I noticed it when I was pulling a trailer on a grade and saw smoke in my rear view. Pulled over to check level. Still had enough to make it home.
I have scheduled an appointment with local Ford dealer. They said it sounded over the phone like a front pump seal.
I think the oil blew back on some wires or something because now my fuel guage is working again. It hasn't worked in thousands of miles.
'94 4.0L 110,000 miles
Old Mar 8, 2004 | 02:56 PM
AdiDcn's Avatar
AdiDcn
thank you i just took it back today and they told me same thing exept the part of poor aligment this shop sux im tired of them
Old Mar 9, 2004 | 09:19 AM
jwirth's Avatar
jwirth
What shop do you use? It is not a Ford place, is it?
Old Mar 9, 2004 | 12:47 PM
AdiDcn's Avatar
AdiDcn
no ford charges way to much
F-erOnlyRunsDwnhill
Mar 30, 2014 05:16 PM
ty8573
2009 - 2014 F150
Nov 20, 2012 10:39 AM
GaSouthern250
Nov 13, 2011 06:28 PM
