Fuel Filter Disconnect Tool
Old Mar 6, 2004 | 09:06 PM
khmorse's Avatar
khmorse
I know I need a Fuel Filter Disconnect Tool. When I went to the Advance Autoparts website, I found three different tools. Which one is the correct tool for an Expedition?
1.
2.
3.
Thanks
Old Mar 7, 2004 | 12:43 AM
Racerguy's Avatar
Racerguy
The top one is what you need.
Old Mar 7, 2004 | 06:39 AM
khmorse's Avatar
khmorse
Thanks.
Old Mar 7, 2004 | 03:07 PM
khmorse's Avatar
khmorse
Bought tool #1 and it worked fine. Thanks for the help Racerguy. No real way to keep gas from splashing down on you though. There isn't a lot of room of there to hold the tool, pull the line, and make sure that both the filter and line stay pointing up so you don't wear gas.
Old Mar 7, 2004 | 08:08 PM
MisterCMK's Avatar
MisterCMK
I am gonna have to do my fuel filter soon, would working with a pan on your chest work? I have a shallow pan, 1", but it is big enough to cover me. I was hoping that would work.
Old Mar 7, 2004 | 08:49 PM
Racerguy's Avatar
Racerguy
Always hold a rag over the fuel lines when you remove them and try to stay as far away as possible.
I hate smelling like gas so I always wear rubber gloves too.
Old Mar 7, 2004 | 09:34 PM
MisterCMK's Avatar
MisterCMK
I haven't looked at the filter, but it should have some rubber lines from both sides, and you should be able to clamp them off with a vice grips. Maybe I can pull this off without spilling any gas.
Old Mar 7, 2004 | 09:50 PM
Racerguy's Avatar
Racerguy
The lines are hard plastic and steel braided. I think you'll destroy them if you clamp them off. Maybe not immediately but.....
Old Mar 8, 2004 | 12:08 AM
hceptj's Avatar
hceptj
I also wrap a large rag around the line as I disconnect...that will get 90% of it.
Old Mar 8, 2004 | 01:40 AM
pounder90's Avatar
pounder90
Let the pressure out of the line with the Schrader valve on the passenger side fuel rail. There isn't much pressure, but it'll help a little. I just positioned my body more towards the center of the truck instead of right under the filter. Less than a pint of gas drained out of the filter.
Old Mar 8, 2004 | 05:25 AM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
The Schrader valve solution is a good one. But not knowing exactly where it was located and the thought of a misdiagnosis had me concerned. So when I did my fuel filter replacement, I pullled the fuel pump fuse while the truck was running, and let it starve itself until it died. No squirts of gas as a result when I disconnected the old filter. There was still fluid in the lines, etc. but nothing with pressure that could squirt out.
On a slightly different note, does anyone know where the fuel filter is located on a 2003 Expedition EB? I've been on my back for 15 minutes straight looking for it, to no avail. I found the filter on my F-250 in a few seconds, but can't get it on the Expedition!
Old Mar 8, 2004 | 02:28 PM
MisterCMK's Avatar
MisterCMK
Did you try the drivers frame rail? It can be kind of hard to see on the 1st generation expys, but I would think its in the same place. Otherwise, just trace the lines from the gas tank till you find a filter.
Old Mar 8, 2004 | 04:44 PM
Sigmund's Avatar
Sigmund
I was about to replace the filter on my 98 Navigator. What is the tool for and will I for sure need it?
Old Mar 8, 2004 | 05:27 PM
khmorse's Avatar
khmorse
The fuel filter locks into the line. Yes, you will need the tool or you WILL not get the filter unlocked from the line. I don't care how hard you pull (tried it). The tool was only $5.99 at Advance Auto.
Old Jun 6, 2004 | 12:07 PM
aalk's Avatar
aalk
Is that part number: Ampro T700453460? I couldn't find anything referencing just the T70045 number listed in the #1 link.
