d60 highboy swap
Old Mar 6, 2004 | 05:52 PM
chimpter's Avatar
chimpter
Question d60 highboy swap
I know it is possible to swap a high pinion d60 from a 1978 - 1979 f250 in to a highboy with just changing the shock tower mount location on the passenger side. I need to know does the front driveshaft need to be shortened if the vehicle is not lifted? What about with a 4 inch suspension lift? Also is it possible to keep the stock power assist setup or would I have to swap to the true power steering? Is there any other items that need to be changed that I have overlooked?
Old Mar 6, 2004 | 08:38 PM
skuteman's Avatar
skuteman
.............You really should shuck the old psteering system as it is a money pit and can never really be counted upon . If , the control valve doesn't function Exactly as it was designed , it can sometimes be almost impossible to steer the truck. It can be a very dangerous situation if you're in traffic and can't maneuaver , which is why I got rid of mine. If , you go with a 4 inch lift you will need a new pitman arm to compensate for the angular difference. Can't help with the DS length. Also, there is a kit on Ebay that is a really good solution to the psteering conversion problem. It is a complete kit that doesn't require any welding, just drilling of holes for mounting the steering box on the inside of the frame.........s.kuteman
WA74Highboy
Dec 22, 2014 03:26 PM
77429highboy
Nov 27, 2012 08:51 PM
r2000f150
Apr 12, 2010 12:55 PM
starmilt
15
Feb 15, 2010 04:32 AM
