Bronco II Ford Bronco II
locking hubs
Old Mar 10, 2004 | 08:13 PM
Shovelhead 93's Avatar
Shovelhead 93
locking hubs
I have a 1990 Bronco 2,the hubs wont engage,I canhear the electric motor engage the transfer case but hubs wont lock what gives???
Old Mar 10, 2004 | 11:46 PM
mrshorty's Avatar
mrshorty
Auto hubs quite commonly fail. Not sure on all the possible failure modes, but sometimes the "points" on the cam break and won't bite, or something else breaks.
1st thing I'd do, is verify visually that the transfer case is really engaging when you hear it work. check the driveshaft and make sure it's spinning. Then replace the auto hubs. Be a lot cheaper to replace them with manual hubs.
Old Mar 11, 2004 | 08:41 AM
bgnbfy88's Avatar
bgnbfy88
After turning them on try driving it backwards for a couple of feet it may assist in the locking but first as said before engae the 4 wheel and check to see if the driveshaft has locked in. If so I would drive it backwards for a couple of feet then see if it engages the hubs. Treat it the same as disengaging the hubs. If the thing doesn't engage the driveshaft then tap it with a hammer if it then goes in you have a funky solenoid that needs to be replaced or cleaned.
Steven Stocki
Dec 4, 2016 08:01 PM
Bigred16
Apr 28, 2016 10:51 PM
swampfire79
Jan 25, 2016 12:16 AM
Troy_455
Jul 13, 2015 08:37 AM
mattsautobody442
2004 - 2008 F150
Mar 3, 2013 09:12 AM
