View Poll Results: topic rating
good
0%
fair
0%
bad
0%
the worst
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
300 6 Carb Problems???
Old Mar 5, 2004 | 07:18 PM
1978F150's Avatar
1978F150
Question 300 6 Carb Problems???
I need help with my 1978 F150 Flairside pickup 300 -6 CYL. When I shut off the truck and wait a second or so it will turn over if I turn the key to the on position [not all the way to start]. Could this be gas leaking or dropping from the carb?
Old Mar 6, 2004 | 12:27 AM
larry derouin's Avatar
larry derouin
It's probably your idle set too high and the engine hasn't quite stopped turning when you turn on the ignition again. Have had plenty of cars/trucks do that if the idle isn't just right.
Make sure your engine is in time, the mixture is set correctly and the idle speed is correct. If it still does it, wait a few more seconds.
Old Mar 6, 2004 | 02:55 AM
scroob's Avatar
scroob
Your idle adjustment is wrong.
The idle on these models should be set with the anti-dieseling device, not the idle screw.
The anti-dieseling device kicks out when the key is turned off, hence, no dieseling.
Old Mar 8, 2004 | 08:35 PM
1978F150's Avatar
1978F150
I don't think I explained the question right. After having the engine off (even for several hours), when I turn the key to the first notch, (without hitting the starter) the engine turns over just enough to make the fan turn over (a revolution or two).
Thanks in advance,
derk001
Oct 9, 2012 08:56 PM
custom1106
WTB - Parts & other
Dec 29, 2010 05:20 PM
meyer1015
Mar 2, 2010 01:05 AM
poknox
Jul 23, 2005 06:38 PM
Grinder619
Jul 29, 2004 01:53 PM
