E4od trans? surges...
Old Mar 5, 2004 | 06:14 PM
overtime_ranchero's Avatar
overtime_ranchero
When I drive along a smooth straight road at about 35 - 40 mph, I sometimes notice that my truck seems to lunge / surge fore and aft. Does not seem like fuel / engine problem, but may be related to a shimmy / shudder that I posted a couple of posts back. Truck has a decent vibration upon acceleration from a stop up to about 15 mph, gets worse when towing 8000 # load. Truck has 51K miles. Have also noticed a little bounce in the speedometer at highway speeds, probably about 3 mph.
Thanks to all, Dan...
Old Mar 6, 2004 | 10:52 AM
NoMo's Avatar
NoMo
Clean the speed sensor in the rear diff and see if that helps.
Old Mar 7, 2004 | 02:48 PM
overtime_ranchero
Thanks,
Will give it a shot...
Old Mar 8, 2004 | 09:40 AM
Lookinfurfun's Avatar
Lookinfurfun
Have you changed the fluid yet? Have you checked for codes? Have you tested the MLPS? If those don't pan out I would start to lean toward the torque converter. But definitely look at everything else 1st.
Old Mar 8, 2004 | 08:45 PM
overtime_ranchero
Do need to service the trans., what is the MLPS?
Dan...
Old Mar 9, 2004 | 11:32 PM
Lookinfurfun
Definitely do a tranny service. There is a writeup in the tech articles section of this web site.
MLPS....manual lever position sensor
20powerstroke02
Feb 18, 2017 07:17 AM
FERdter
Dec 8, 2016 07:20 PM
OnlySS
51
Mar 26, 2016 12:10 AM
cam1394
Nov 24, 2005 09:09 PM
sewhalen35
Nov 1, 2004 06:27 PM
