Apparently I do not have factory clearance lights They are some Made in taiwan crap. I ordered the clear lenses from Stylinconcepts and that is when I knew I had aftermarket ones. Does anyone have a close up shot of one you can email me? I want to see how they look. I guess I will go to Ford and order a set of OE ones.
joey, i got mine at aa autoparts they are the same as ford oem .just go by a dealer and get up on the front tire and take a look.thats what i did then took a couple measurements so i got the spacing right. lot cheaper then dealer . if you dont have the factory wiring then you wire to the light switch. just tap into the parking lights wire and your all lit up.
Thanks for the helpful hint. I take it in Monday anyways for a tranny flush to the Ford dealer. I should of known when I switched out me turn signals with clears, and noticed a wire spliced into them. Not a big deal, just if I ever need them replaced, I have no idea where to get them. They are a little bit wider and longer then the OEM, and they mount with two screws on each side of the light. So I would need to fill the screw holes to mount OEM lights. I may just have the removed and fill/paint the holes.
