Frozen Distributor
Old Mar 5, 2004 | 12:02 AM
nielmans'77's Avatar
nielmans'77
Question Frozen Distributor
'77 F-150 351M NP435 4.11LS
Frozen distributor. Anyone have any ideas that might free it up? I've cranked on it pretty good with a pair of channel-locks without success. Not much room to work.
Thanks.
Old Mar 5, 2004 | 11:43 AM
beeboy's Avatar
beeboy
On mine I had to:
Soak it awhile with penetrating oil.
Get a slide hammer hooked to it with a chain and try to jerk it up.
Hammer it with a punch, on the driver side there is a flat tab that extends out on the metal part of the body.
After a few days I got it to start moving and finally pop out.
Old Mar 5, 2004 | 11:44 AM
TomThrall's Avatar
TomThrall
This thread has been visited here several times. These engines have a bad habit of sticking, because the gasket area sits low in the block casting and collects water/dirt/antifreeze etc..
Just soak it with some kind of penetrating fluid and you will have to get rough with it. Some distributors have a squarish area on the bottom where you might be able to get a wrench of some type on it, or large channel locks, but often you have to get rough with them to the point of destruction. I had one stuck that I had to get a bar and beat on the vacuum advance shoulder with a bar and hammer to get it to break free.
I do not know any magic bullets that will fix this easily, since there is no way to know just how frozen yours is.
Old Mar 5, 2004 | 02:00 PM
nielmans'77
Thanks for the input.
I'll start getting rough with it.
Will let you know how it goes.
Thanks guys
Old Mar 5, 2004 | 06:44 PM
F150daniel's Avatar
F150daniel
engine hoist.
Old Mar 5, 2004 | 09:52 PM
beeboy's Avatar
beeboy
neilman, after the effort it took to get it out, I decided it was probably a good time to replace it. I'm not sure how much pounding they can take before they deform, but that along with the slop in the bushings sold me on a new dizzy.
Old Mar 5, 2004 | 09:58 PM
79F150400M's Avatar
79F150400M
Yep...had that problem too. I poured a small amount of clean motor oil around the base of the dizzy...let it soak for about a week...and then popped it out with a BIG screwdriver. When i re-installed the new dizzy, I put some moly grease around the base and slipped er back in the hole. Good Luck!!
Old Mar 6, 2004 | 02:36 AM
scroob's Avatar
scroob
Anti-seize is the best insurance, since distributor is aluminum and block is cast iron.
Old Mar 9, 2004 | 09:25 PM
nielmans'77
I've been letting it soak all week and will try again this weekend.
Anti-sieze? Thanks for all the input.
Old Mar 10, 2004 | 02:36 AM
Torque1st's Avatar
Torque1st
Posting Legend
I use AS in the oil pump drive hex also.
Old Mar 16, 2004 | 07:39 PM
FortyFords's Avatar
FortyFords
pb blaster works every time for me !
let it soak overnight
Rich
Old Mar 17, 2004 | 12:39 AM
nielmans'77
Thumbs up
I was able to bust it loose last weekend. After soaking all week with penetreting oil, I put channel-locks to it, clamped the handles and used more torque.
Thanks for all the input and tips,
Scott
77flareside
Apr 17, 2010 06:49 PM
msteelsos
Feb 21, 2007 09:29 AM
david troupe
Oct 24, 2003 05:59 AM
Frozen1
Exhaust Systems
Jan 27, 2003 02:20 PM
Matt
Dec 17, 1999 02:27 PM
