They also should vary according to engine size. IE: a 240 should normally be metered a hair less than a 300. I've got these specs somewhere, but probably take me a month to find em... MK
The 300-6 was originally an industrial engine, for running wood chippers, gensets, etc. The cfm is just about perfect for running a constant 3,000rpm, right between the torque and hp peaks.
mmmMM! Lets see, 300 cu in displacement divided by 1728 = .1736 cu ft displacement X 3000 rpm = 520.8 cubic feet per minute
But it takes 2 revolutions for all six to fire 520.8/2=260.4 cfm of air sucked thru the carb @ 3000 rpm.
