Someone please check these out
Old Mar 4, 2004 | 05:53 AM
Icicle's Avatar
Icicle
Question Someone please check these out
Will someone please check these heads out and tell me what they will really do on a stock 400.....not much of a genius with heads and help would be appreciated before bidding on them.....are they streetable with premium gas (92 octane here) with or without additives on a stock 400 in a bronco?
thanks
kevin
Heads on Ebay
Old Mar 4, 2004 | 11:29 AM
prostocktom's Avatar
prostocktom
They would be a great improvement over your stock heads. Your compression ratio would be in the 9.5 to 9.75 range. But since the Aussie heads have a small combusion chamber you'll get a much improve quench area in the head, so you should run excellent on 92 octane with no problems. Might even get by with 89 octane ok. Put yourself a MSD iginition box on there and I know you could use cheap gas with no problems.
Old Mar 4, 2004 | 01:18 PM
Bill_Beyer's Avatar
Bill_Beyer
Those are nice heads but there are some things to keep in mind. A factory stock 400 has the pistons sitting down in the bore >.050". In order to obtain any advantage from the quench effect of those heads the piston needs to come within .040" of the heads. Typically head gaskets are between .035" and .040" thick so the pistons need to come up to virtually "zero deck" to utilize the quench advantage.
Most rebuilder type pistons are "destroked" .010" - .020" to allow for block decking and head resurfacing which means the pistons will sit even further down in the bore. If you rebuild the bottom end you need to find out what the compression height of the pistons you're using is.
Old Mar 4, 2004 | 02:18 PM
grclark351's Avatar
grclark351
http://raceabilene.com/kelly/hotrod/compression.html
some standard inputs are .040" gasket thickness, 4.1" gasket bore diameter for Fel-Pro blues. these are also variable depending on your choices, as are the rest of the blanks.
Old Mar 4, 2004 | 04:21 PM
coburnm's Avatar
coburnm
i am so so sorry, i cant belive i forgot, what is quench, it has ben a long time sence i have heard that.
Old Mar 4, 2004 | 04:36 PM
Bill_Beyer's Avatar
Bill_Beyer
Check this thread out:
https://www.ford-trucks.com/forums/s...hreadid=212537
Old Mar 4, 2004 | 09:08 PM
crossbeed_65's Avatar
crossbeed_65
I have a 400 that I will be rebuiling shortly. I was planning on puttin in cleveland flat tops bored .030 over. Would heads like the aussie heads allow me to run regular (stock style) pistons, taking into acount the 30 overbore, and still have the high cr? I am looking for at least 9.5:1. I will be adding an MSD ignition. Lastley, would it still run on pump gas at this cr or even a bit higher? (we only have 91 around here )
Thanks
Old Mar 5, 2004 | 12:24 AM
prostocktom
Crossbeed_65 If you plan to use Aussie heads and drive it on the street you will want to use your factory pistons. If you used flat top pistons your compression ratio would be in the 10 1/2 - 11 to 1 Great for 100 octane not good for 91 octane. Just changing to Aussie heads will amaze you how much better a bone stock engine will run. Also 351 Cleveland piston will not directly work in your 400 without some major modifications $$$ But you can buy 400 flat tops If your had your heart set on them.
Old Mar 5, 2004 | 02:49 AM
crossbeed_65
Thank. But by no means was I planning on running the Aussie heads with the flat tops. I was merely trying to get some opinions on what people thought was better.
Old Mar 5, 2004 | 06:47 PM
Ecuri's Avatar
Ecuri
Here is a lot more detail on quench.
http://www.speedomotive.com/Building%20Tips.htm
Old Mar 5, 2004 | 08:37 PM
Matts72's Avatar
Matts72
Thats Dennis Carpenter selling those on Ebay. thats definetly one guy that knows his fords!
Old Mar 5, 2004 | 09:01 PM
Torque1st's Avatar
Torque1st
Posting Legend
Unfortunately 9.5:1 will require detuning to run on pump gas which negates the gains the increase in CR provides. If the engine they are going on has been decked or the heads need milling to clean them up the CR goes even higher.
Maybe someone knows where to get 0.060 or 0.080 thick head gaskets. Stacking two head gaskets is really not a good idea.
There have been very complete discussions on these heads and quench here. To do the job right takes custom reverse dome pistons, not just dished, that conform to the shape of the combustion chamber.
Old Mar 5, 2004 | 10:00 PM
grclark351's Avatar
grclark351
sce has the gaskets up to .090 something thick. the complete url won't post?
Old Mar 5, 2004 | 10:04 PM
grclark351's Avatar
grclark351
here is a partial listing of what is available under the 351C application. there is a .093 thickness also.
http://www.austrackmotorsport.com.au...%20gaskets.htm
Old Mar 6, 2004 | 12:38 AM
pcmenten's Avatar
pcmenten
Kevin,
No need to be in a hurry to buy Oz heads, they come up all the time. The price on this auction is starting to creep up. Phil "Ausheads' in Portland will sell them for a good price. He's an Oz import, himself.
The difference between these heads and standard Cleveland (not the 351M/400 heads) is the shape of the chamber. The ports of the 351C heads and the Oz heads are the same. The problem is the large displacement of the 400 and the small size of the Oz chambers; compression will be too high.
Short answer, get some 351C heads (not the 351M/400 heads, but the 70-74 Cleveland heads) and spend your money on the best valve job you can get. I got some 351C heads off of ebay for $25.
