What is Quench?
Old Mar 2, 2004 | 11:10 PM
dbarracuda's Avatar
dbarracuda
What is Quench?
Hey guys Some someone explain to me what "quech effect" is and its benifits or give me a link to a thread that has dicused it?
Thanks
David
Old Mar 3, 2004 | 01:44 AM
Bill_Beyer's Avatar
Bill_Beyer
On a "closed chamber" type head the quench effect results from the top of the piston coming in close proximity (<.040") to the flat part of the head which is inside the combustion chamber area. It has 2 different advantages, 1 the turbulence helps to ensure a more complete burn of the A/F mixture and 2 the flat portion of the head can help dissapate some of the heat that builds up in the top of the piston. It allows you to run a slightly higher compression ratio than an engine with no quench.
Old Mar 3, 2004 | 09:04 AM
dbarracuda's Avatar
dbarracuda
Thank you very much
David
