rear end u-bolts
Old Mar 3, 2004 | 08:45 PM
96-5spd302's Avatar
96-5spd302
rear end u-bolts
where can i get longer read end u-bolts, the local stores says he cant get them the right width apart that i need?
Old Mar 3, 2004 | 08:51 PM
Beast12's Avatar
Beast12
I know you can go to some transport truck places and they bend them for you. Go to a transport truck repair place that does bigger trucks. Good luck!
-Matt
Old Mar 3, 2004 | 10:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
Spring shops also have them or can make them.
Old Mar 6, 2004 | 02:43 PM
78F100's Avatar
78F100
http://www.eatonsprings.com/
Old Mar 6, 2004 | 04:48 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Where are you located? Like Eric said, any spring shop should be able to get them, or bend them for you
Old Mar 7, 2004 | 12:27 PM
96-5spd302's Avatar
96-5spd302
i am located in southern ohio, about 65 miles east of cincy.
Old Mar 7, 2004 | 12:41 PM
Torque1st's Avatar
Torque1st
Posting Legend
Most larger cities will have spring shops. Ask in any shop that works on commercial trucks.
Old Mar 7, 2004 | 02:43 PM
skuteman's Avatar
skuteman
If its Not to much work remove one of your OLD ubolts and carry it with you and find a source that will fab you anew set of bolts and use your old one to ensure the correct spacing. s.kuteman
