98 Mountaineer, rumble when turning
Old Mar 3, 2004 | 12:54 PM
mattb0519's Avatar
mattb0519
I have a 98 mountaineer, 5.0L AWD with 133,000 miles. Starting approximately 2 months ago I began hearing a low rumbling noise while turning at low speed under power. (It is similar to the noise a tire will make on a rubberized floor when turning the steering wheel while not moving , although deeper.) It occurs in either left or right turns and is not present under any other conditions.
Any ideas would be appreciated.
Old Mar 3, 2004 | 05:34 PM
mjbach's Avatar
mjbach
Do some searching as there is lots of information here regarding tire noises that you will have to sort through to get an accurate match for your noise.
Recently, we had the tire noise on a X with a limited slip differential and what fixed the noise was changing the fluid and additive. Your noise might be different.
Pew Professional
Aug 28, 2016 09:34 AM
carolinaborn82
Nov 12, 2015 10:16 AM
bjj9611019
3.8 & 4.2L V6
Jul 23, 2010 09:40 AM
jclowdis
1997 - 2003 F150
Jan 24, 2008 09:14 PM
slowsix
Nov 17, 2001 10:12 PM
