Sponsored by: Auxito
Rumble noise need help
Old Jan 23, 2008 | 06:27 PM
jclowdis's Avatar
jclowdis
Exclamation Rumble noise need help
Guys i need your help again, i have a 2000 F 150 5.4 4x4 ex cab 170,000 miles . I have a vibaration problem and a loud rumble coming from the rear. The rumble only occurs when i run it up to about 75 and over and then let off the gas. 75 mph and over is also when the vibration occurs. I have had the wheels balance 3 times, i have installed new u joints. Any ideas. thanks alot.
Old Jan 23, 2008 | 07:14 PM
ford_boy_1996's Avatar
ford_boy_1996
Go slower!!! LOL J/K Is the drive shaft out of wack
Old Jan 23, 2008 | 07:28 PM
jclowdis's Avatar
jclowdis
ya the speed limit is only 65 lol, ya i looked it over real good and it looked fine but after reading in my haynes manual maybe i should look a little closer.
Old Jan 24, 2008 | 12:57 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Bearings in the rear axle might be starting to go out....
Old Jan 24, 2008 | 07:32 AM
jclowdis's Avatar
jclowdis
you mean the axle bearings or bearings in the guts it self, i know quite a bit of mechanical stuff but i never have had to mess with an axle much.
Old Jan 24, 2008 | 12:53 PM
ford_boy_1996
To take apart the rear end you need to jack up the rear end and take the rear cover off. Then there is a 8mm headed bolt you will need a 6 point 8mm wrench watch out you don't brake it. Take that out and then slide the big pin out from your spider gears. Then back off your rear brakes and take the drums off. Then push the axles in and then the the u clips that hold the axles in... The u clips are in by the spider gears once they are out pull the axles out and look at your axle bearings... good luck! Thats the best I can tell you how to do it
Old Jan 24, 2008 | 01:47 PM
jclowdis's Avatar
jclowdis
thanks alot for your help
Old Jan 24, 2008 | 06:44 PM
tampa898's Avatar
tampa898
Yup happened to mine. It was the bearings.
Old Jan 24, 2008 | 09:14 PM
jclowdis's Avatar
jclowdis
well took the pan off my rear axle today had my dad help me hes worked on several axles neither one of us could tell a thing wrong the gears all looked good, no metal shavings, bearings felt good. I'm now back to thinking maybe its one or all of the tires. the only thing that kind of baffled us was that when we turned the drive shaft by hand it turned really easy one way and sort of hard the other. that was with it both hooked up to the axle and unhooked. Also the axle turned real easy after we unhooked the drive shaft. Thanks for all your help and advice.
jspringator
Jan 6, 2016 06:59 AM
carolinaborn82
Nov 12, 2015 10:16 AM
csblunt
Nov 9, 2005 04:59 PM
homer4.2
3.8 & 4.2L V6
Aug 28, 2004 02:58 PM
vanlohd
Aerostar
16
Mar 22, 2004 11:03 AM
