Speed Sensor Question
Old Mar 3, 2004 | 10:29 AM
satcomjimmy's Avatar
satcomjimmy
My Speedometer and Odometer stopped working at the same time, so I am about to go get that checked. I was wondering about another symptom that popped up at the same time. When I start it up, it runs fine until the first time it shifts to 3rd. It is very reluctant to shift and as soon as it makes that first shift, the OD Off light comes on. It flashes until I stop and turn off the truck. The next time it is driven, it is the same thing. Is this possibly all the speed sensor?
Old Mar 3, 2004 | 10:36 AM
mrshorty's Avatar
mrshorty
What year? and yes, it could easily all be in the speed sensor.
Old Mar 3, 2004 | 10:40 AM
satcomjimmy
its a 95 explorer limited 4x4, a few months back it was giving a trouble indication of incorrect gear ratio after 3rd was commanded which seemed to clear with a fluid flush and filter change. Speed sensor sounds cheap, is this something fairly easy; should I take it in or lift it and change myself?
Old Mar 3, 2004 | 12:50 PM
87 XLT's Avatar
87 XLT
Pull the codes, if the speed sensor is bad you'll get a code.
Old Mar 5, 2004 | 07:38 PM
dlhazel's Avatar
dlhazel
Red face speed sensor
The spped sensor is real easy. I replaced mine and I am a girllll. It is on the rear of the tranny on the drivers side. I think it is a 10 or 11 mm socket. Expect a bit of fliud to drain. I think it costs about $25.00. You will need to push in the sides of the old one to remove the gears and install on new one. Slide into hole and put bolt back in. Done!!! If your speedometer is workinng right you did it correctly.
Old Mar 6, 2004 | 02:21 AM
Opera House Works's Avatar
Opera House Works
Might be worth while to just remove the connector on the speed sensor and reconnect it in case it is a corrosion problem. It is easy enough to get at on the side of the transfer case. Remove sensor first and inspect the plastic gear. Some have reported this cracking. New speed sensor will not come with a gear and you will have to transfer it.
Old Mar 6, 2004 | 12:42 PM
northsea's Avatar
northsea
speed sensor
94 F150 6 cylinder I am trying to find the speed sensor would anyone know?
Old Mar 10, 2004 | 09:08 PM
mwblackman's Avatar
mwblackman
What does the speed sensor look like?
Old Mar 13, 2004 | 07:51 AM
northsea's Avatar
northsea
The location on my 94 Ford F150 was on the top front of the rear differential. I did not have to remove mine since my problem was obvious, the wire to it were broken. I spliced the wires and all is well. I guess the wires simply broke after 10+ years of swinging. I used extra wire ties to pevent some of the movement and swing of the wires.
ScottSC
Snowking
Dec 10, 2010 11:55 PM
wilevel2
Jul 7, 2009 04:24 PM
Bertelrud
Apr 29, 2009 05:39 PM
ronclark
1983 - 2012 Ranger & B-Series
May 2, 2006 09:39 PM
wnpguillory
Apr 14, 2006 01:11 AM
