1978 - 1996 Big Bronco
leaking bronco
Old Mar 2, 2004 | 03:03 PM
Broncobigtire's Avatar
Broncobigtire
Unhappy leaking bronco
Hey all. This post is not one on a good note. A while ago I began to see water spots inside the ol' bronco and so I took it apart and noticed that the "soft stuff" under my vinyl was soaking wet. I have found that there are holes on each side of the car, just back from the rain gutter things. Should I go ahead and replace all of the weatherstripping? Also this is on a 92. Also, does anyone have suggestions on how to repair the holes? Shoould I just weld some sheetmetal over them and such? Also, dealing with the vinyl and carpet stuff, I was wondering if anyone has rhino lined or the equlivient of rhino lined the bottom to rid themselves of carpet/vinyl...This is because there are pretty good sized crackes in the floor boards and it would help repair them..Thanks...Any help/suggestions is welcome
Old Mar 2, 2004 | 03:34 PM
BillyBob69's Avatar
BillyBob69
For the Rhino lining...do a search on this forum..there was a post a couple of weeks ago that had a link to detailed steps on doing just that. As for the holes. do you mean cracks from the rain gutters back to the removeable top? or in the channel that the top sits in? Either way, there have been alot of people that have welded the holes/cracks closed, grinded smooth then repainted.
Old Mar 2, 2004 | 04:42 PM
bigric's Avatar
bigric
Yeah, you've got the body cracks. Check out this thread:
https://www.ford-trucks.com/forums/s...hreadid=124977
This topic has been covered pretty well in the forum.
Old Mar 2, 2004 | 05:23 PM
Broncobigtire
Does anyone know where i can get this kit: Roof Repair Kit (F5TZ-9850223-A). ? Do I need to go to the local ford dealership or can I order it online somewhere? Thanks.
Old Mar 2, 2004 | 06:31 PM
bigric's Avatar
bigric
It's a dealer item, but the word is that it isn't in production any more.
Here's what it looks like, thanks to Gacknar:
https://www.ford-trucks.com/forums/s...hreadid=153367
shanes66charger
May 10, 2009 08:42 AM
time537
1983 - 2012 Ranger & B-Series
Dec 5, 2005 02:49 PM
Lex Talionis
Dec 25, 2004 07:40 PM
VIBR8R
18
Aug 28, 2003 10:59 AM
84bronco2
Bronco II
Jul 14, 2003 08:26 PM
