You can use the 351m bell or 400m bell...they will both bolt to the np435. If it is an internally balanced 460 you can use and FE flywheel. Again you will need different motor mounts and towers, i got mine from landlproducts.com You will need spacers in between the bell and block if you use the 3 finger clutch. I'm not sure about spacers with a diaphram clutch.
You need to space the bellhousing approx. 3/8" from the engine block because the crankshafts on the 460 werent drilled deep enough for the input shaft. I think the best spacers are the stock plate that goes between the bell and engine, using 3 of them worked for me.
