Vin/data Plate Help
Old Mar 3, 2004 | 07:54 AM
faslane's Avatar
faslane
Vin/data Plate Help
i have noticed that a few people have got help with there vin and data plate decoding, i was wondering if someone could help me out with mine. thanks. my 1968 reads as followed
vin# f10ycc18845
WB-131
COLOR-M7
MODEL-F100
BODY-81
TRANS-B
AXLE-08
MAX WHEIGHT-5000
CENT. HP-172
RPM-3800
DSO-21
and there is a plate on the firewall that has the vin and M7 space K space 4. thanks for all the help.
Old Mar 3, 2004 | 01:23 PM
joadmobile's Avatar
joadmobile
I can't recommend enough that you go to Motorhaven and get this book:
http://www.motorhaven.com/customer/p...cat=125&page=1
In its 71-72 incarnation it has answered virtually every question I had about trim levels, factory options and VIN decoding. Thanks for offering it, Ken!
The factory manual on CD-ROM doesn't hurt to have, either.
Old Mar 4, 2004 | 06:31 PM
mk's Avatar
mk
F10YCC18845
F10- Half ton
Y- 360 cid
C- Oakville, Ont assembly
C18xxx- Sept 67 scheduled build date
M- Wimbledon white
7- Harbor blue
B- 3 spd o/d trans
08- 3.50:1 axle ratio
21- Atlanta sales district
I'm curious about that tag. Does it have rippled edges and is it stapled on the firewall above the master cyl? This is called a body buck tag and the 67's had them attached to the same spot. I've found on most 67s I've looked at that after about April of 67, they stopped putting them there. These tags seem to be rarely found on the trucks between then and 72. A good place to look for info on those tags is 67Fordtruck.com. Thom's got some good stuff there. Anybody else know more about these tags?
mike
Old Mar 5, 2004 | 07:51 AM
faslane's Avatar
faslane
yes it is the tag you are describing, thanks for the help on the numbers, i will check the site out on the buck tag. thanks again.
Old Mar 5, 2004 | 04:11 PM
mk's Avatar
mk
You may have to email Thom from his site as I'm not sure he has figured out all the codes on these tags.
mike
