explorer fuel pump problem
Old Mar 2, 2004 | 01:00 PM
memphisfordguy's Avatar
memphisfordguy
My son's 1991 explorer sport has an unusual problem. The fuel pump continues to run when the car is turned off, even if the key is removed. He has to pull the fuse in the engine compartment to shut it off. The gas mileage has dropped substantially at about the same time this started to occur. Any advice??
Old Mar 2, 2004 | 02:14 PM
87 XLT's Avatar
87 XLT
Tell your son to pick up a new fuel pump relay -10 bucks- at Napa etc. They should be able to tell him where the relay is located. Unplug the old, plug in the new. This will most likely fix it.
Old Mar 3, 2004 | 01:56 AM
memphisfordguy
Thanks for the tip... but no good. The pump still runs. Any more ideas? Thanks for the help
Old Mar 3, 2004 | 02:35 AM
bigric's Avatar
bigric
I've seen this caused numerous times by a bad ECU. Be very careful with this problem--if the injectors open, it will dump lots of gas into the cylinders, past the pistons, and into the oil. If this happens, the fuel pump will be the least of your problems.
Old Mar 3, 2004 | 06:49 AM
Opera House Works's Avatar
Opera House Works
What do you mean it still runs? Sure you got the right relay? When the EEC relay opens (key off) it drops power to the fuel pump relay coil. You would have to have too many individual failures for the pump to keep running. Go back and chec your steps.
Old Mar 3, 2004 | 09:47 AM
87 XLT's Avatar
87 XLT
I agree, it sounds like your son swapped the wrong relay. BTW when comes to fixing electrical problems the "electrical & vacuum troubleshooting manual" is XLNT & only 30 bucks from www.helminc.com
