1978 - 1996 Big Bronco
Tailgate cable removal/ high amp alternator
Old Mar 2, 2004 | 11:25 AM
sdrowand's Avatar
sdrowand
Does anyone happen to know what size torx bit is required to remove tailgate cable, also where is a good place to get a high quality 130-160 amp alternator. By the way i have a 1996 E.B. bronco 5.0L. thanks
Old Mar 2, 2004 | 11:50 AM
BroncoRoadKill's Avatar
BroncoRoadKill
Not sure of the torx bit size. but your beonco should have a ford 3G alternator. Not sure if it's the 95A. or the 130A.
Note that the 130A. is capaple of 160A.
Old Mar 2, 2004 | 01:18 PM
fishin machine's Avatar
fishin machine
I used a pair of vise grips, worked great.
Old Mar 2, 2004 | 06:11 PM
bsmith's Avatar
bsmith
I just went out and checked for you. I have a full set of torx and none of them fit. That bolt is actually just a big phillips head (on my 88). The vice grip idea sounds good to me.
Old Mar 2, 2004 | 09:22 PM
timack's Avatar
timack
torx bit is T50
Old Mar 3, 2004 | 07:32 AM
sdrowand's Avatar
sdrowand
Thanks i will get a t-50 bit
Old Mar 3, 2004 | 08:35 AM
Kikwear's Avatar
Kikwear
I used a pipe wrench and a big philips head last night. Worked great.
Old Mar 3, 2004 | 09:42 AM
Will_01_GT's Avatar
Will_01_GT
Originally posted by timack
torx bit is T50
Definatly a size T50, also get replacements for both, the new one will be a tad shorter, plus a few days after I install the driver side the damn passenger side was starting to split. Just remeber to do the one at a time
mattymax
Jan 7, 2016 10:50 AM
KDAVID1
Jul 26, 2015 09:14 PM
kbarbee95
Jul 9, 2015 03:10 PM
FordTruckChuck
1997 - 2003 F150
Apr 4, 2015 08:57 AM
Totally Tuna
Aug 1, 2014 01:55 PM
