Here we go, Ford over timing chain issue SOHC!!!! Help!!
Old Mar 14, 2004 | 09:01 PM
madd's Avatar
madd
Wink
Hey,
I am still waiting for my 97 sohc to be fix. The tech from Ford said the same thing. When all the recalls are fixed, the motor kicks ....I am just waiting for one more part to come in and than I am in business. I hope that it will be it.... ....I can't deal with any more or I will be sick... I will keep you guys posted,,,,
Old Mar 15, 2004 | 01:18 AM
Benelli Boy's Avatar
Benelli Boy
Hey Madd,
Are you doing the work yourself and what parts are you going to replace? I may be in the same boat.
Old Mar 15, 2004 | 01:27 PM
Baileydog's Avatar
Baileydog
Timing Chain
My 2000 Explorer just began to sound like a diesel - and the head gasket had begun to leak - according to Ford, and another independent I consulted, the motor is toast and I have a choice of a new one or a rebuild - the dealer said the timing chain had broken and there were metal bit all over. We have had it since October 03 and it always sounded a bit rough - we had the tensioner done under the recall.
We have chosen the new motor as we got the truck for a decent price and the new motor has a two year or 40,000 km warranty. Is the new motor likely to be better than the original?
I take it this problem isn't covered by the warranty we were just talking about since they can't seem to fix this motor....or is it?
Old Mar 15, 2004 | 08:24 PM
dogman's Avatar
dogman
It will be as long as they put the new timing chains and tensioners in. I would do it with the motor is out. Its cheeper. I would look at putting in the rear seal to that way you dont have to look for leaks. Just my 2 cents.
Old Mar 15, 2004 | 08:59 PM
madd's Avatar
madd
Hey, Benelli Boy and Baileydog,
Benelli Boy: What I am doing is replacing the tensioners and timing chain guides and cassttes. All of them. I am also replacing the gears to the timing chain (just in case they are bad). I had to get gaskets for the rear, spacer, bolt and intake gasket, and a tensioner for the timing chain and since the motor is out, I am having the rear and main seals replaced. I am having a ford tech do it on the side,,,, ,.......I am just waiting for one of the gears to come in.
Baileydog:I don't know what motor you plan to replace it with. But, if your vechile is under the 100,000 miles or 7 years they should uphold the original warranty even if they replace it with a new one. I am not a true buff in knowing all about motors, that's my husband's job... But, since I am the one dealing with the dealers on the parts, I have learned fast. Just keep asking around and when not for sure, get a second opinion. I hope this helps anyone who is screwed with this problem. I will let all of you guys know when my motor gets fix.
Old Mar 19, 2004 | 01:36 PM
MikeMc100's Avatar
MikeMc100
I'm thinking about buying a 2002 with the 4.0 SOHC. Had all of the timing problems you are talking about been addressed by the 2002 models? I don't see any compliants from this model year. Thanks.
Mike
Old Mar 19, 2004 | 06:59 PM
madd's Avatar
madd
Post
.....Hey,
To answer your question, they fixed the problem and left everyone with a 1997-2000 and mountineers 2001 screwed. I am having my 97 fixed as we speak, but, got bad news last night. He feels that I should have the heads and look into a block.
Well, I might as well rob a bank, because I had blown my wad into buying this piece of crap and all the recall parts to fix it. So, I plan to get the motor back, drop it in and grab my ankles. I suggest you go to the dealers and have the service tech to pull the vin info on it and check if their was any outstanding warnings(another word used for recall, only if the owner should complain)on it so you can learn now instead of later.......I hope this helps .....let me know
Old Mar 22, 2004 | 04:52 PM
jaystersj's Avatar
jaystersj
Damn Ford, Mines still making the noise,, after the dealer wouldn't replace it because its not loud enough yet. Call Customer Service and put in a complaint. They have it all on file now so if they motor goes, its there wallet , not mine.
Old Mar 22, 2004 | 04:59 PM
dogman's Avatar
dogman
If you have the papers on it, they have to fix it. Your going to have to be a bug on there butt about it. Call them everday untill they fix it.
Old Mar 22, 2004 | 05:51 PM
madd's Avatar
madd
Angry
I AGREE W/ DOGMAN.... BE A TOTAL PAIN IN THEIR BUTT. IT'S YOUR MOTOR NOT THEIRS ... THEY JUST WANT TO WAIT SO YOUR WARRANTY WILL RUN OUT AND YOU WILL HAVE TO GRAB YOUR ANKLE.... NOT THEM ..... IF THEY STILL WON'T DO IT. CALL BBB OFFICE AND FILE IT ..... YOU HAVE THE RIGHT TO HAVE THEM FIX NOW UNDER THE WARRANTY. ....
Old Jun 18, 2004 | 09:02 AM
cage71's Avatar
cage71
tensioner/timing chain
I have this same noise on my 2001 ranger 4.0 still under full warrenty thou and i believe there is suppose to be a recall on those parts aleast thats what the dealer told me .. I cant wait till they get mine done I hate that darn rattling noise. Hech and I only have 29,000 miles on mine... I also think there is suppose to a full kit for it so I wonder if they replaced every thing they were suppose too.. the first time..
this is all the info I have for know when it gets done ill pass on anymore info i can........... later guys ...
Old Jun 19, 2004 | 04:33 AM
madd's Avatar
madd
Sorry to hear about your problem .... But, since I got mine fixed, she had been running sweet. I am glad I got this one and stuck with it. ...
I hope things work out for you too. I hope to hear from you the next time.
Old Jun 19, 2004 | 07:06 AM
  #28
Huffer's Avatar
Huffer
Cool
My 98 Mountineer is the LAST peace of Ford CRAP I'll ever be buying!! Every new generation of engineers and satisticians(bean counters) that the manufacturers get cause more customers to become disloyal to the brand! If these jerks would consentrate on consistant customer satisfaction they wouldn't have to be scrambling all over the globe for cheap labor and part suppliers. A satisfied customer is the utmost insurance for a thriving business!
I had Ford look at my noisy 4.0 sohc and they kept putting me off. They know damn well what the problem is but would rather save a penny now but lose me as a future customer. WELL,THEY CAN CONSIDER THEIR MISSION ACCOMPLISHED!
Huffer
Old Jun 19, 2004 | 08:38 PM
  #29
madd's Avatar
madd
Exclamation
That is how I actually felt and wrote emails to them and dateline and anyone I thought of. I used all my money to buy this thing and it was messed up!!!!!
I am only grateful that I was able to fix it by myself and it is doing fine. I own a GMC EXT- TRUCK , FORD TEMPO, FORD BRONCO II, FORD ESCORT STATIONWAGON, HAS AND FORD RANGER, CHEVY CAMARO 82 AND AN 84, and I can only say I have been the type to buy cash and what I could afford.. I never had a loyal manuf. to stay with. I just wanted something that would last and I could afford. So, when my crap started. I was ready to sue someone for this design fawl. But, my husband wanted to fixed it and keep it and I had wanted to sell it cause I was mad at Ford for it.
But, it all worked out so far.......I plan to buy another vechile for my daughter soon and I need to sell two the car just sitting in the driveway. Soon, my same method applies. I hope this time I dont have to milk more money into it right after I buy it....
Old Jun 20, 2004 | 10:29 AM
  #30
timmyjoe's Avatar
timmyjoe
I feel your pain my 2000 Ford Explorer Sport as 109677 KM is going in the shop again for the samme noise with 200 Km left on my ford ext. warrenty.The replace this piece last novembre.Two times now unreal.
