cleaning the engine
Old Feb 29, 2004 | 07:09 PM
dandep's Avatar
dandep
cleaning the engine
Ok this might be a stupid question but here goes. I want to power wash my engine compartment soon. With all the salt this winter here in MA. I want to clean it good. I'll use some type of engine degreaser first then power wash it down. It's onlt a 1600 PSI washer. Is there anything I need to cover or be concerned about.
Thanks in advance.
2000 X Limited
Old Feb 29, 2004 | 10:49 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Your owners manual shows a page of what to cover... or maybe it's the additonal diesel booklet for diesel engines???
Usually it's the electronic stuff and airfilter. I have washed mine off and the key is not to hold it in any one position and "force" water into small key areas. Just give it a gentle rising and slowy go over all areas 1 or 2 times.
Good luck,
Old Feb 29, 2004 | 10:59 PM
68torino's Avatar
68torino
Keep the nozzle back a piece from any electrical. The key is letting the degreaser do the work and the washer to RINSE off the loosened material.
Old Mar 2, 2004 | 01:39 PM
MW246's Avatar
MW246
I power washed my once and will never do it again. That wash job cost about $80. after I had to change my coil because it got wet and shorted out.
Old Mar 2, 2004 | 02:58 PM
spartan's Avatar
spartan
Just don't stick the nozzle of the power washer right against the the electrical components and you will be fine. I wash my engine a couple of times a year with the degreaser and have had no problems.
Old Mar 3, 2004 | 09:32 AM
scottmotorsports's Avatar
scottmotorsports
All I have ever used is Simple Green to clean my engines. 2000 Ex with a V10, I spray it with full strenght Simple Green and let it soak alittle, then just spray with a garden hose. Has always com very clean and doesn't leave that white resedue I always got with the spray engine cleaners.
Old Mar 26, 2004 | 06:26 AM
n5qwa's Avatar
n5qwa
I have always washed my engines at the car wash with the engine cleaner (looks like Simple Green), and prudent use and targeting pressure and direction without problems....
grimmwit
2015 - 2020 F150
34
May 25, 2020 10:34 AM
Wacky Wick
2015 - 2020 F150
Apr 9, 2017 03:45 PM
PPrash
Dec 27, 2016 01:12 PM
Cesar Salcedo
Jul 31, 2016 09:55 PM
fdude64
Jul 20, 2015 06:39 PM
