5.0 engine cleaning
Old Apr 7, 2017 | 08:53 AM
Wacky Wick's Avatar
Wacky Wick
5.0 engine cleaning
I have a 2016 f150 and want to clean my engine bay, I want to wash my engine down but too many wires look like would short out.... Anyone out there wash their 5.0's ?
Old Apr 7, 2017 | 09:43 AM
Dodgerguy's Avatar
Dodgerguy
I don't have a 5.0 but I do detail engines on my other vehicles. I'm not a big beliver in spraying water on the engine for many reasons although I know others do it with success. To me there is too much risk of getting water in various electronic parts. I have a large supply of old rags and towels and use those dampened to wipe down the engine bay after every other wash or so. I also use a little 303 protectant on the rubber parts that look faded. I find it's a lot easier to keep it looking nice by doing this every other wash or so than to try to bring it back after it has gotten really bad. That means you may have a lot of work cleaning it up the first time but after that it should be a lot easier. You can also do a lot of reading on engine detailing by going to some of the car care websites that sell detailing supplies. Good luck and let us know how it turns out.
Old Apr 7, 2017 | 09:53 AM
Wacky Wick's Avatar
Wacky Wick
Thanks, thats what I was going to resort to, rags and getting in there . CRC 6-65 for me though just like on my outboards.
Old Apr 7, 2017 | 10:01 AM
Dodgerguy's Avatar
Dodgerguy
Good luck. If you can post pics when your finished. I'm looking toward either a 2017 or 2018 with a 5.0. Are you happy with the performance and which rear end did you go with? Will help me decide.
Old Apr 7, 2017 | 10:05 AM
Kingofwylietx's Avatar
Kingofwylietx
I've never washed a 5.0, but I've always sprayed down my engines a couple of times a year. I live in an urban/suburban area, so no dirt roads for me...which means my engines don't really get that dirty.
They say not to use high pressure sprayers in your engine bay, that can force water into loose connectors, etc. However, a normal garden hose should be fine...these things are designed to get wet. I've never had an issue just using a garden hose and I've been doing that for about 30 years.
A real plus to keeping it clean is that you'll more quickly notice if you develop any type of leaks, especially oil or from the water pump.
Old Apr 7, 2017 | 12:37 PM
Wacky Wick's Avatar
Wacky Wick
Truck has plenty of sack, 3.31 rear
Old Apr 8, 2017 | 08:02 AM
GABAR's Avatar
GABAR
A steam cleaner would be the best option for cleaning the engine compartment.
Old Apr 8, 2017 | 09:43 AM
Dodgerguy's Avatar
Dodgerguy
Engine Cleaning | MotorWeek
I would be afraid of steam cleaning with today's engines. Some interesting reading.
Old Apr 8, 2017 | 10:12 AM
Wacky Wick's Avatar
Wacky Wick
Simple degreaser and CRC 6-56 Bam !
Old Apr 8, 2017 | 10:36 AM
Dodgerguy's Avatar
Dodgerguy
Wow. That worked! Very nice. Thanks for posting the pic. You've given me incentive to go do my 98 again.
Old Apr 9, 2017 | 08:07 AM
Deanp88's Avatar
Deanp88
Did my 5.0 a couple days ago. Sprayed grease remover then a light spray of water to wash it off. Then I sprayed shine then a light spray of water to wash that off. Then I used an air hose and dried like crazy. Let it sit for 5 hours and it still stumbled when starting for the first time. Something to think about...
Old Apr 9, 2017 | 01:35 PM
JKBrad's Avatar
JKBrad
Why spray shiney junk on it? It attracts dirt and breaks down the"eco friendly" corn based decombosable wiring insulation.
Old Apr 9, 2017 | 02:06 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I used to spray down my old '86 with the 300 pretty routinely but I haven't dared to spray an engine since that one.
Old Apr 9, 2017 | 03:40 PM
GABAR's Avatar
GABAR
I should have elaborated further on the steam cleaning.
One should use a portable steam cleaner that has a small nozzle on the end of the hose so when you hit the area with the steam, you should use a towel to wipe away the moisture.
The type of steam cleaner that the video is referring to is the type that some of the old car washes would use or even some of the larger portable but commercial steam cleaners and I would agree that those might cause problems for an engine bay.
I`ve been using a portable one for over ten years and i`ve also used it 3 times on my 2016 Lariat without any problems.
Hope this helps.
Old Apr 9, 2017 | 03:45 PM
CuNmUdF250's Avatar
CuNmUdF250
I never even go under my hood... probably had it up 3 or 4 times in the 3 years I've owned it. I wouldn't spray water in there for any reason unless it was on fire
ford12508
General Automotive Discussion
Jul 20, 2010 02:57 AM
ctboyle03
1983 - 2012 Ranger & B-Series
Jan 21, 2007 07:40 PM
rlh68050
Jul 8, 2005 07:02 PM
Y2K350
Modular V10 (6.8l)
Apr 29, 2005 01:31 PM
IES
Jun 18, 2002 04:24 AM
