Windshield Wiper Off the Windshield
Old Feb 29, 2004 | 05:08 PM
TMG2's Avatar
TMG2
My wiper blade on the driver's side didn't go down all the way after a snow storm. Now it is wiping too far to the left, going past the end of the windshield and getting stuck. Anyone else had this problem before?
Old Feb 29, 2004 | 07:18 PM
FTE Herman's Avatar
FTE Herman
No, but you might have to remove and re-align it.
Old Feb 29, 2004 | 10:30 PM
tsdrallyer's Avatar
tsdrallyer
IF you are lucky you can just reset it. It is more likely that the wiper was frozen to the windsheild and the torque of the motor stripped out the serrations in the wiper arm that fit around the post. In that case, get a used wiper arm from the salvage yard.
Old Feb 29, 2004 | 11:38 PM
PaulC's Avatar
PaulC
Pry off the plastic cap at the base of the wiper arm, remove the nut holding the arm in place, clean the (very fine) splines on the stud, replace wiper arm in correct location, tighten nut, replace cap, you're done. The wiper arm does not have any serrations, but presents a smooth, conical hole. I have a new driver's side wiper arm, purchased from Ford,that supports this point.
The slippage is like a safety valve that prevents toasting the linkage in the event that the arm binds on the windshield.
Old Mar 1, 2004 | 10:01 AM
tsdrallyer's Avatar
tsdrallyer
I stand corrected, I had only seen the old ones and assumed they were stripped. I've never had a problem with mine.
rob1994AerostarAWD
Aerostar
Dec 25, 2008 08:33 AM
evan250
Sep 12, 2004 09:01 AM
kspilkinton
1997 - 2003 F150
Dec 29, 2002 05:08 PM
Jujubabe
Dec 18, 2002 01:35 PM
Superdave
1978 - 1996 Big Bronco
Mar 13, 2000 09:30 AM
