low oil pressure 1989 7.3 idi
i have a 1989 ford f350 with a 7.3 ,there is a problem with the oil pressure ,i put a mech gage on it.allmost no oil pressure at a idle.when i rev it up the oil pressure comes up and then falls off ,it bounces around up and down.at idle it shows no oil pressure.what could this be ?? also it blows alot of blue smoke and idles really ruff.i just put in a new 1 piece lux flywheel .it was shaking before and after i put it in .i loosened the injector lines one at a time and they all seemed to make a difference .where would i find the block numbers to determine the yr of the motor thks
hmmmmmmmmmmm, might be bearings causing the oil pressue problem or in the oil bypass system - a wacky valve in there. There should be numbers on the block here ... standing at the front of the truck, to the right of the injection pump housing there is a flat area on the block --- look there.
NOT SURE BUT I THINK ITS LOCATED IN THE FILTER BULKHEAD OF THE OIL COOLER.
I KNOW ON THE 6.9 ITS LOCATED IN THE FILTER END OF THE OIL COOLER. I INSTALLED A REBUILT MOTOR IN MY COUSINS TRUCK LAST SPRING. IT HAD A LOW OIL PRESSURE PROBLEM. SO WE REPLACED THE OIL FILTER BULKHEAD END OF THE OIL COOLER. PROBLEM SOLVED.
GOOD LUCK!
GOOD LUCK!
I have a ford f350 w/7.3 diesel. it has 120K. I have a similar problem with oil pressure. truck runs fine and sometimes the oil pressure is really low then other times it's normal or othr times next to nothing. yet i never hear the expected low pressure sounds from the engine. I chaucked it up to a bad oil guage. but maybe it's more serious.
ebg_51,
Welcome to FTE and the IDI diesel forum.
What the stock oil pressure gauge says really means nothing.
If you want to know what is going on, get a mechanical gauge.
Mine does the same thing but it is not that way on the mechanical gauge.
If you replace the sending unit it will work better for about 6 hours.
About the same can be said about the temp gauge, but it is slightly better.
91ford7.3
07-09-2016 02:06 PM
FF1311
08-11-2015 09:56 PM
riverratba
1999 to 2016 Super Duty
12-01-2009 11:51 AM
