Electronic ignition conversion for '74 F250
Old Feb 29, 2004 | 03:49 PM
dishguy's Avatar
dishguy
Question Electronic ignition conversion for '74 F250
I have a '74 F250 with breaker points, and a dead '76 F250 with a factory electronic ignition setup. Anybody know how to easily swap the electronic setup into my '74? Thanks!
-Do not post telephone numbers on the web- Admin
Old Feb 29, 2004 | 04:30 PM
73Custom's Avatar
73Custom
If it's the same engine, it would be easy. Just swap the dist and install the wiring harness and module. The hook up keyed power to the red wire (on 2 wire terminal on module) and it's set.
Marty
Old Feb 29, 2004 | 05:10 PM
mhg's Avatar
mhg
check out gofastforless.com
Old Feb 29, 2004 | 09:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
You may find lots of info in your engine forum also. The wiring forum is also a good source.
Rogue_Wulff
May 5, 2012 11:30 AM
wckdclwn911
15
Nov 10, 2004 09:15 AM
Crew_Cab+
Electrical Systems/Wiring
May 29, 2004 10:20 PM
racerp419
Feb 23, 2004 10:29 PM
1ross
Feb 27, 2001 04:45 PM
