Professional Code Reader
Old Feb 28, 2004 | 03:05 PM
doc_nomad's Avatar
doc_nomad
I have two professional code readers at work (I am not a mechanic, I am an auto theft investigator and we use these to identify computers in cars). So, I really do not know how to use them. They are both quite a bit larger than the aftermarket ones and have a lot more buttons.
I have one that is made by Diamler Chrysler and another made by GM. Both have OBDII connectors and a couple of other connectors. My question is what connecters do I use to hook up to my 94 F150 5.8 to get codes. I hooked the Chrysler one up to a 2000 Crown Vic and it worked, but I dont think my 94 has a OBDII.
Is anyone familiar with either of these machines. Do I need to get a pci card for pre-OBDII vehicles.
Old Feb 29, 2004 | 02:00 PM
ninjaplumber's Avatar
ninjaplumber
What brands are they??? I have a 92 f150 (pre-obdII) and 95 GMC jimmy (obdII) At the time I bought mine, I had to purchase two seperate units, one with a "ford" plug, and one with a "generic" obd II plug, obviously I am not able to use generic one on my ford, because it wont fit, not the other way around. I am also not able to swap the actual units (the handheld units). They are not compatible. But I have called the manufacturer and there are updates available to make them compatible. I hope this helps...let me know if there is anything else.
Old Feb 29, 2004 | 02:04 PM
brown 4x4's Avatar
brown 4x4
If they're made by Chrysler and GM, are you sure they can read other manufacturers' pre-OBD-II codes? OBD-II is more standardized, that may be why it read your 2000. Your '94 should be OBD-I.
I've used a couple Snap-on scanners, and they use adapters for each manufacturer that attach to the end of the cable. If that's the case with yours, you'll need the Ford style adapter.
Old Feb 29, 2004 | 08:15 PM
doc_nomad's Avatar
doc_nomad
I will try to hook them up with an OBD I connector tomorrow. I just want to pull the codes. We will see if they will recognize the pre 96 codes. Thanks for all the help.
Where is the OBD I connector located, under the dash like OBD II?
Old Feb 29, 2004 | 10:42 PM
brown 4x4's Avatar
brown 4x4
Under the hood, driver's side near the firewall. There's the connectors with a black plastic cover saying "EEC test" pinned to the inner fender.
waterbear
Aerostar
Oct 27, 2012 08:30 PM
npearman
Mar 24, 2008 06:43 AM
DGMFORD
1997 - 2003 F150
Mar 16, 2007 10:12 PM
Crumm
Jul 14, 2005 01:07 PM
StevePA
1997 - 2003 F150
Apr 24, 2003 07:43 PM
