Check the break on-off (boo) switch on the break pedal.My rangercruise didnt work because the bracket was bent, But yours may be different. Hope this helps. Vin 95
Mine did the same thing. It was the cable from the cruise control servo to the throttle body. It just snapped right back on. Hope its that easy for you.
When my clock spring broke, the first noticeable effect was my cruise stopped working. Then my air bag light started flashing code 32. Then my horn went. Took awhile for all the symptoms to show. The ribbon in the clockspring breaks slowly. Remove the CS and check continuity between the connector ends, top to bottom.
