Paint for Driveshaft?
Old Feb 28, 2004 | 02:38 AM
BLACK350/6.0L's Avatar
BLACK350/6.0L
Just looking for some advice on what type of paint for my drive shaft? What type primer and what type paint? Is the drive shaft hard to remove any advice appreciated? What is the best way to remove that rust any tips?
Old Feb 28, 2004 | 05:47 AM
Lashlaroo's Avatar
Lashlaroo
I would start with a P.O.R product. Do a search for "por-15" You might find that to be good enough?? If not I think I would use an oil base. Jack up the rear end on some GOOD stands, let the truck idle in drive. Light pressure on some steel wool, run it down the drive shaft.
Old Feb 28, 2004 | 05:53 AM
mikelehmann's Avatar
mikelehmann
I just did mine with marhyde spray rust inhibitor 5$ a can i used two cans. turns that rust into a black primer sealer. personally there was enough room under the truck too get all of the front and 3/4 of the rear then i just moved the truck a few inches and finished the rest.
Old Feb 29, 2004 | 12:09 AM
BLACK350/6.0L
Lashlaroo,mikelehmann
Thanks for the input will try this out real soon!! And report back!!
clintonvillian
May 19, 2015 08:23 PM
hooler1
Mar 31, 2015 06:50 AM
F-250 restorer
33
Sep 11, 2014 11:01 PM
chrlem
Mar 16, 2014 07:28 PM
Bessie
32
Jan 21, 2011 10:44 PM
