high rpms
Old Feb 27, 2004 | 05:44 PM
trader rob's Avatar
trader rob
high rpms
I have a 88 f250 4x4 7.3, is it normal for this truck ,when you wind it out in any gear, not tight mind you , but when you hit about 2000 to 2500 [ im not sure how close the rpms are, tach don't register right all the time]. it is like a 2 stroke coming on the pipe. now im not complaining about the power, but shifting is hard, the rpms fall off slow, so its like speed shifting or when you let them fall it stands you on its nose in next gear. can you see what i'm saying? i drive a truck for a living so i'm not completly in the dark. international of course. lol
Old Feb 27, 2004 | 06:43 PM
mhalter's Avatar
mhalter
I had this problem with my 89 7.3. The likely culprit is the vacum modulator valve. It is located on the side of the injection pump. It is plastic and is adjustable. It has two vacum lines running to it. Replacing this solved the problem for me. I was unable to locate the part at any other place than Ford. It was $90 from them. This is all assuming you have a C-6 three speed automatic by the way.
Old Feb 28, 2004 | 04:41 PM
trader rob's Avatar
trader rob
no i have 5 speed, wouldn't be a problem, but when it gets wound out a little the rpms shoot up real fast then drop too slow. have sprayed off linkage so it is not gummed up. don't know.
Old Feb 28, 2004 | 05:15 PM
rancherman84's Avatar
rancherman84
did you unhook the throtle cable and try just moving the pump lever.if that fixes it ,that would eliminate the cable binding for sure.could be an internal pump problem.
lablue96
Dec 15, 2011 06:40 PM
Mr. Man
Apr 3, 2009 02:04 PM
BDFD
Sep 12, 2008 03:19 PM
V8EXPLR
2004 - 2008 F150
19
Jun 12, 2008 10:49 AM
Skidly
Apr 30, 2005 11:24 PM
