Flame Thrower Install....Which wire needs to be tapped!
Old Feb 27, 2004 | 11:10 AM
mudinford's Avatar
mudinford
Howdy,
need to install a Dual Flame Thrower Kit on a 5.4L 2000 ish F-150. The kit has a module and a relay. The Kit requires you to bypass the wire that supplies + power to the coil (or coils in this case) and route it through a relay to by-pass the single to remote coils/plugs back on the tail pipe. So what happends is that the injector fires off but no spark. Then the unburned fuel gets expelled into the exhaust where it is ignited by the secondary coil/plugs. Now the probs it that there is 8 coils on this motor! Is there one wire for all 8 or 8 wires i have to worry about. I know the computer supplies ground pulses to the coils to fire. So there is always a hot when the truck is in run/start to the coil. Any info will help! Thanks!
Dan
Old Feb 28, 2004 | 09:19 PM
bob arrington's Avatar
bob arrington
are you talking about blowing flames out your exhuast?bob
Old Feb 28, 2004 | 09:31 PM
ZombieSlayer's Avatar
ZombieSlayer
Yep that's what he's talking about. I'm curious...are you sure there are 8 coils? That just doesn't sound right to me...but I'm by far an expert.
Old Feb 29, 2004 | 09:53 AM
bob arrington
wire it to any 'ignition hot' circut' , thru a switch so you can controll it , and have fun, in the old days , we used to install a spark plug in the tail pipe ,and run a small tube with an electric pump from the fuel line thru a switch...., but thats another wood stove story,bob
Old Feb 29, 2004 | 09:58 AM
mudinford's Avatar
mudinford
On the 5.4 Triton motor, there is 8 individual coil packs on top of the plugs. This kit would only work if you didn’t have Cats. SO, since the truck would not run correctly if the cats were removed, we nixed the idea. Plus the complex wiring to bypass the coils that I would be guessing at. Sucks, he bought the kit and everything!
And yes! The kit says that you can get up to a 20' flame out of the pipe! I, myself, would not do such a thing....more of a favor to a friend. O well....thanks for the replys!
Dan
Old Feb 29, 2004 | 12:24 PM
greasymonkey's Avatar
greasymonkey
.........really?-a 'flame thrower' ignites unburnt fuel out the exhaust????????--this sounds strange,and extremely dangerous for off-roading and fire hazards!!!!
Old Feb 29, 2004 | 03:27 PM
bob arrington
the old way was much simpler, and im legal,and im not going to give complete directions , but if you can find a mechanic , over 50 years old that used to play in the streets ,etc........bob
Old Mar 4, 2004 | 05:48 PM
Old Ford Fan's Avatar
Old Ford Fan
C'mon Mr. Bob..... you giving us the details isn't illegal. It's only illegal if someone does something stupid and then only for the one that does the stupid thing. That's why people can write books on commiting the purfect murder or how to be an expert sniper. Information is just that, information.
So please help us young 40+ year olds and share some of that excellent information.
Thanks,
Jeff
Old Mar 4, 2004 | 06:07 PM
Mil1ion's Avatar
Mil1ion
The instructions are on Google
Old Mar 4, 2004 | 06:26 PM
Old Ford Fan
Thanks oh mighty one . I really value all the info I see posted from you. Should I just search for "flame thrower."
Thanks and keep up the outstanding work,
Jeff
Old Mar 4, 2004 | 09:41 PM
bob arrington
respectfully,bob
Old Mar 4, 2004 | 09:46 PM
Mil1ion's Avatar
Mil1ion
Jeff,
here you go :
http://www.flamethrowers.com.au/
Buy something from motorhaven now okay
mmagang06
May 10, 2013 01:07 PM
70-360fe
Dec 25, 2011 02:23 PM
jchamp429
27
Dec 18, 2011 08:56 PM
TxF100
Feb 17, 2009 09:31 AM
kwanderi
Feb 8, 2004 05:17 AM
