Sponsored by: Kumho
wheel hop
Old Feb 27, 2004 | 12:27 AM
bigblocksix's Avatar
bigblocksix
wheel hop
hi everyone, i have a 1990 f250 with a horrible case of wheel hop. it hops on dry pavement, wet pavement, mud, gravel, dirt, anything! i have friends with the exact same truck that have no problem. on guy says that my leafs are weak from the heavy loads the previous owner hauled and that a spring re-arc will cure the wheel hop. theres no sag in the back end and the truck sits level so i dont know. anyone else had this problem??? how do i fix it? as for a spring re arc do i just bring the springs in and say re arc these back to stock?
Old Feb 27, 2004 | 04:23 AM
85351ho's Avatar
85351ho
is this a 4x4?any lift?
Old Feb 27, 2004 | 07:45 PM
bigblocksix
its a 4x4, no lift
Old Feb 28, 2004 | 11:25 AM
bob arrington's Avatar
bob arrington
id be more inclined to check the tire balance,bob
Old Feb 28, 2004 | 12:55 PM
bigblocksix
the tires are freshly balanced, it just seems to brake traction realy easily on take off and bounces up and down
Old Feb 28, 2004 | 03:16 PM
SoCalDesertRider's Avatar
SoCalDesertRider
If the truck is sitting level when empty, it's actually sagging, since those trucks sat about 2 inches higher in the rear when stock and unloaded. However, I dont know that that condition would cause what you're describing.
How are your rear shocks? Is this happening when in 2wd on a smooth road, or is it a washboard or otherwise bumpy road? When you go over a bump does the thing keep bouncing up and down like a spring-- boing, boing... that would indicate worn out shocks.
I get wheelhop on bumpy roads when unloaded in the F350 and used to get it in my old Chevy dually and old Chevy 3/4 ton as well. That's just the nature of stiffly sprung heavy duty trucks when unloaded and driven on bumpy and especially washboarded roads.
With the old Dodge 1/2 ton I didn't get that because the truck had a softer suspension, the axle didn't weigh as much, and I had a camper shell that gave it some weight back there.
I would think that if your shocks are good and your rear springs are a little worn, the ride would actually improve a bit over a stiffer newer spring...
Old Feb 28, 2004 | 06:05 PM
bob arrington
check your steering stabilizer , if you are running other than stock wheels ,or even stock , that could be your problem , the only other thing would be tie rod ends , id bet money on the stabilizer though,up here they call it snow plow shakes, bob
Old Feb 28, 2004 | 11:36 PM
Josh79's Avatar
Josh79
make sure your steering stabilizer is not loose. it was loose on my 79 f 150 and it would shake you to death sometimes
Old Feb 29, 2004 | 02:23 PM
mrwizard's Avatar
mrwizard
How would the steering stabilizer affect the rear wheels?
Old Feb 29, 2004 | 02:38 PM
GeorgeofGeorgia's Avatar
GeorgeofGeorgia
How are your leaf spring bushings where they bolt to the frame?
crazymut
Aug 29, 2009 01:23 AM
fisher1995
Mar 9, 2007 10:28 AM
Vampiro
Mar 24, 2002 09:47 PM
shotgunner426
Jan 27, 2002 10:41 PM
TLR
Nov 17, 2001 10:49 AM
