Sponsored by: Real Truck
low fuel indicator
Old Nov 26, 2001 | 06:59 AM
JEFFnSTL's Avatar
JEFFnSTL
low fuel indicator
Does anyone know how many more gallons of fuel are left in your tank when the it trips the low fuel indicator light on the dash. 2001,sc,4x4,5.4,38 gallon tank. Thanks!
Old Nov 26, 2001 | 08:01 AM
scaesare's Avatar
scaesare
low fuel indicator
I usually have 4-5 gallons left. Mine is an '2, however.
-Steve
Old Nov 26, 2001 | 09:25 AM
rob_n_houston's Avatar
rob_n_houston
low fuel indicator
Check your manual. I believe I read mine a couple years and it said you have 12% left. OK I'll do the math, 4.56 gallons. Mine seems to be spot on.
Rob
Old Nov 27, 2001 | 03:44 PM
Vaccuum's Avatar
Vaccuum
low fuel indicator
My light goes on...I procrastinate...then I fill up. 22-23 gallons I pump. So, if it's really a 29 gallons tank, that leaves it at about 6 gallons of reserve. Not a good reason to let it go so low, but at least it gives a good safety margin.
Hope it helps.
Old Dec 4, 2001 | 06:47 PM
Joneser's Avatar
Joneser
low fuel indicator
I agree with the other 2 guys approx 5 gal left usually sometimes more depending on how level I am when I start it up lol
Old Dec 5, 2001 | 07:42 PM
JEFFnSTL's Avatar
JEFFnSTL
low fuel indicator
Thanks for to replies. It seems everytime the indicator comes on and I fill up (38 gal tank) it only takes 31-32 gallons. Thanks again. Love the site!
Old Dec 6, 2001 | 06:59 AM
mickssd's Avatar
mickssd
low fuel indicator
I've the 01 Lariat that has the miles remaining display on the overhead consol. When the low fuel light comes on it shows approx.
30-40 miles remaining. It seems to be fairly accurate because its been down to 1 mile and I was able to squeeze in 29.3gal. I say squeeze because after the first click of the pump I'm still able to get 2-2.5gal. into the tank. It takes awhile because you have to run the pump slow.
Old Dec 6, 2001 | 09:14 AM
mjake's Avatar
mjake
low fuel indicator
I have a 2001 F-250 and when the light comes on I have about 4 gallons left. I hope that helps:P
Old Dec 6, 2001 | 10:13 AM
mjake's Avatar
mjake
low fuel indicator
FastEddie_1
Jul 18, 2021 07:40 AM
boatnfish
2009 - 2014 F150
Aug 29, 2009 06:47 AM
barrelhorses
Modular V10 (6.8l)
18
Dec 7, 2008 09:38 PM
AB328
2004 - 2008 F150
13
Jul 16, 2007 06:47 AM
Capt Dan
Oct 21, 2003 06:50 PM
