Sponsored by: Real Truck
Chassis Lube E 250
Old Feb 25, 2004 | 06:15 PM
monstaeye's Avatar
monstaeye
Chassis Lube E 250
I have a 2003 Econoline 250. What kind of grease is recomended for front end lube. Info not in owners manual. This vehicle also doesn't have kingpins. There are no zerk fittings where kingpins should be but there are little plug bolts that look like they can be replaced with zerk fittings. Should they also be lubed? The other ball joints came with fittings.
Old Feb 27, 2004 | 09:14 PM
cocot's Avatar
cocot
Any type of front end grease is good. I happen to use marine grease. Unscrew the bolt screw in a zerk and grease.
JohnnyAirtime
Apr 14, 2016 05:43 PM
Cy Madrone
Transit Connect
Aug 11, 2011 02:33 PM
iron1951
Sep 27, 2009 08:59 AM
JQ
Oil & Lubrication
May 12, 2006 10:35 AM
amaezing
1997 - 2003 F150
Feb 16, 2006 06:02 PM
