'90 F250 Leaf Spring Thickness
Old Feb 25, 2004 | 03:29 PM
jarch's Avatar
jarch
Hello ALl,
I have a '90 F250 4x4 Supercab with a 351 Engine. The GVW is 8800 LBS. It is the heavier duty F250 with a Dana 60 Rear and a Dana 50 IFS Front Suspension.
The kid that I bought it from has a 4" lift on it, and I would like to replace the lift with a stock suspension for driveability reasons.
Does anyone know the thickness of the stock front leaf springs? 1.45" or 2.03"? I think they are a 2 spring arrangement. I assume the thicker springs were for the diesel, but am not sure. I would like to pick some up tonight If I could.
Thanks,
Jeff
Old Feb 25, 2004 | 06:42 PM
c_rossman's Avatar
c_rossman
Dana 50 up front and Sterling 10.25 full floater in the rear. The diesel had the thicker springs. If u go with a 4 inch lift you will need drop down brackets for you Twin I Beams to keep it aligned.
Old Feb 26, 2004 | 10:30 AM
drool's Avatar
drool
There are a couple of different springs used in the two leaf arrangement. The door sticker will have a spring code which will tell you what came on the truck. If you give the info to a spring place, they'll be able to tell you what to put back to remain stock. In my case it is a 7 which is the 2755lb springs. There is a lighter 2 leaf arrangement and a heavier one that is (I think) for carrying plows). I'm learning this from my efforts to replace my saggy front springs.
With any luck you'll be able to finance most of the restoration to stock by selling off the lift stuff.
Check out the thread "front springs" for a little more info. If you find any good sources for springs, let us know.
PS: You can find out how to ID the kind of rear end you have on the web. I think mine's a Dana 60. 10 cover bolts is a Dana 60. 10.25 is 12.....just got that off the web so it must be true!!!!
Old Feb 26, 2004 | 02:18 PM
jarch's Avatar
jarch
More Info
Thanks guys. Here is some more info.
My door tag:
Springs: 7 F
Front GAWR: 3920 LBS
Rear GAWR: 6084 LBS
GVWR: 8800 LBS
WB: 155
TYPE-GVW: X268
Door Tag on Possible Doner Truck:
Springs: 6 6
WB: 133
Type: F-261
GVWR: 6800 LBS
The springs on the doner truck are 1.45" thick, two leaf and the spring eyes are the same length, so they will physically fit into my front end.
I guess there were two different thicknesses, 1.45" and 2.03". Can anyone tell me from the above info, what front springs I need? I tried the search function, but could not find any info. I want to keep my truck as heavy duty as it was equipped from the factory.
Thanks,
Jeff
Old Feb 26, 2004 | 10:52 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Judging by the GVWR info on the donor truck and your statement that it has 1.45" thick springs and there are 2.03" springs also listed for other trucks, I would say that the springs on the donor truck are NOT the ones you want.
Old Feb 27, 2004 | 01:58 PM
sleepysal's Avatar
sleepysal
FYI you might need to replace the pitman arm . If you have a 4" lift kit they may have used a drop pitman arm or bent your original one. Drool is right you might be able to sell or even trade your lift for stock . Good luck
P.S. How bad does it drive now?
Old Feb 27, 2004 | 06:28 PM
jarch's Avatar
jarch
Thanks for the comments:
It drives just fine. No problems. I just will be using it as my daily driver, and it is difficult to get in and out of. Plus, the tires are robbing some power. I like the feel of 4:10 gears and tires the size of LT265's or so. I will be pulling trailers on occasion and like the more maneageable tires and lower gears. I have an Early Bronco for 4 Wheeling, and this truck is so big that it can't get out of its own way.
PLUS... My wife and I are expecting our first child, so getting in and out will become a more pronounced problem.
Anyway, I have researched spring codes, and it appears that code 7 is 2820 lbs per spring, and code 6 is 2575 lbs per spring. There is also a code 9, which is 3486 lbs. I'm sure those are the thicker springs. The local junkyard has the code 6 springs, which I might try.
The truck is in awesome shape. The original two tone black and blue shines like new and the interior is flawless. It is an XLT Lariat with all of the options at the time.
Thanks for the help! I do think I can sell the lift kit and 35's with 30% tread locally.
Jeff
Old Feb 27, 2004 | 07:19 PM
sonic's Avatar
sonic
ya cant take off the lift just for having a baby.... just kidding man
the hospital people nurses just looked at me kind of funy when i pulled up with my truck, 35's and all, when my first son was born almost 4 years ago. they looked at me odd still when i picked up my second son a year and a half ago. Plus the fact that my wife is only 5'2. i took a little stool with me when i went back to get them, she laughed so hard, then ended up smacking me for making her hurt.
Here's just a bit of carseat info for you... rear facing car seats (even the carrier type with the stay in base) only fit in the middle (with bucket seats) and forward facing fit wherever, behind the driver is tight if you are taller and need to extend the seat the whole way back, my son kicks my seat whn i dont anser him by the 3rd time he asks to stop at mcdonalds
Old Feb 27, 2004 | 11:03 PM
jarch's Avatar
jarch
Sonic,
Thanks for the info. I do have the front buckets, so hopefully the rear facing will work in the center rear. I did a little research on this before buying. As far as the lift, my better half actually likes it. I might just keep it and the 35's around in case I don't like the smaller tires afterall, or if I (gasp) have to buy an SUV someday and retire the truck for weekend service.
Of course, we also have her Subaru Forrester for a little more practicality.
The monster truck is kindof fun. It is a challenge to park at grocery stores, and people in smaller cars think twice about turning left in front of you! Haha. I'm starting to get hooked on it. So far, I have driven about 250 miles, and both my gas tanks are empty. I think my speedo and Odo are about 20% off, but that's still not very stellar mileage. But, that's not what we buy them for.
