Carb Linkage
Old Feb 25, 2004 | 05:53 AM
boomer202's Avatar
boomer202
Carb Linkage
I have a 72 F100/390/c6 and the old Autolite 2 bbl. has developed a leak from the accelerator pump. Turns out the housing is cracked. So...I stumbled across a Holley 2 bbl. The Holley is a list 8226 (Ford OEM from a 75 302 cu in. ) The guy I got it from rejetted the carb and had it on a 390. This weekend I pulled the Autolite 2100 off and went to install the Holley. Problem is there is a big difference in the geometry for the linkage. The linkage setup on the 72 just will not work. Any suggestions?
Old Feb 26, 2004 | 04:25 PM
bob arrington's Avatar
bob arrington
if you are talking about the kickdown for the C6, the easy thing would get the linkage from the 302. if you didnt pay for the holly yet take it back and but one that has the right linkage ,bob
Old Feb 27, 2004 | 06:06 AM
boomer202's Avatar
boomer202
Thanx Bob...the carb has a Ford kickdown connection and that works OK. The issue is that the pedal rod is too short (relative to the carb actuator arm). I think that if I lengthen the pedal rod a bit it will reduce the severity of the "uphill" angle for the linkage rod and might work out. I have already paid for the card (Ebay) so I have no access to the old 302 doner truck. The guy I got the carb from was running it on a 390.
Old Feb 27, 2004 | 10:59 AM
bob arrington
ive cut those and welded a skinny bolt in the gap so i could still have the right ends ,bob
Old Feb 27, 2004 | 02:04 PM
boomer202's Avatar
boomer202
Thanx Bob - will look at it more this weekend. Might try your suggestion...
chefcharles
Dec 9, 2014 12:11 PM
tyrantsparky
Dec 7, 2014 10:25 AM
Handegard
May 27, 2011 11:12 AM
Dean88
Feb 14, 2008 09:36 PM
f100guy
Jan 9, 2005 04:30 PM
