EFI Fuel Rail Schrader Valve Location ?
I was hoping to check my fuel pressure to make sure it was up to specs. Can someone clue me in to the location of the schrader valve ? This is my first I-6 powered truck I have owned. I must say I am inpressed with the nice flat torque curve.
On all EFI Fords I have owned the fuel pressure is usually lower than what the book calls for. Its probably due to the spring in the regulator getting a little weaker as the years go by. Whenever I get a new used Ford I check the pressure, and if it's low I give the regulator a little squeeze untill the pressure is where its supposed to be at.
vjsimone
12-28-2018 08:34 AM
