kill switch
Old Feb 23, 2004 | 10:14 PM
surfer8400's Avatar
surfer8400
kill switch
does anyone know how to wire a kill switch to a 95 ranger?
Old Feb 23, 2004 | 10:22 PM
GoldStarKimber's Avatar
GoldStarKimber
Might not be what you are looking for...but I just ran across this while browsing:
https://www.ford-trucks.com/forums/s...B%25252Bswitch
Old Feb 23, 2004 | 10:23 PM
Franklin2's Avatar
Franklin2
Would you rather it crank but not start, or not crank?
Old Feb 24, 2004 | 10:34 PM
surfer8400's Avatar
surfer8400
i would like it to do what ever is easyest to wire, im not a great electrition, i just know the basics.
Old Feb 24, 2004 | 11:24 PM
Mil1ion's Avatar
Mil1ion
Did you click the link in the reply by Goldstarkimble ?
My reply/answer is in there.
Old Feb 26, 2004 | 10:29 PM
94Bronco58's Avatar
94Bronco58
I put in a killswitch on my 94 bronco, just found the starter wire (forgot what color) and put a switch right between the wire, so you can have it on or off, off will cut off power to the starter!
Old Feb 27, 2004 | 02:06 AM
AlfredB1979's Avatar
AlfredB1979
Not that I can necessarily help, but whoever made the chip/kill switch for my Ranger is good. I pul that chip and it doesn't start, crank, anything really. You can get the "acc" function, but lose that chip.....
I thought about it and I think what I've got goes to the starter and computer--somehow. I don't think the body electronics need the computer, so that makes sense.
Old Feb 27, 2004 | 12:28 PM
Franklin2's Avatar
Franklin2
Well, the easiest would be the "s" terminal on the starter. So it won't crank, but if it's a manual tranny truck, it could be roll started if they jerked the ignition out of the column.
Old Feb 29, 2004 | 07:01 PM
surfer8400's Avatar
surfer8400
so all i have to do is find the starter power wire, then cut it in half, then attach thoes 2 ends to a switch and it will cut power
Old Feb 29, 2004 | 08:05 PM
94Bronco58's Avatar
94Bronco58
Exactly, just cut it, strip it, and mount those two wires on the posts of the switch and your done!
Old Mar 1, 2004 | 06:45 PM
surfer8400's Avatar
surfer8400
i got one more question, the starter on a 95 ranger is mounted on the top or the drivers side firewall, right? also anyone know what wire i should cut?
Old Mar 1, 2004 | 07:36 PM
Franklin2's Avatar
Franklin2
Look for something that looks like this.
http://www.partsamerica.com/product_...mg/NIE/S63.jpg
You will cut one of the wires going to the small terminals on top. Cut the one going to the "s" terminal.
Old Mar 1, 2004 | 09:26 PM
surfer8400's Avatar
surfer8400
whats an s terminal?
Old Mar 1, 2004 | 11:29 PM
Mil1ion's Avatar
Mil1ion
There are either 1 or 2 small terminals on the starter relay.
On the starter relay there is the Letter S which indicates the starter circuit , it should be in-line with the small terminal,
You are basically going to interupt that one wire with a switch so the only way for current to travel through and initiate the starter to turn is with the switch in the closed position,
Remember the Relay !
Using a little current to switch for use of big current.
Old Mar 3, 2004 | 12:25 AM
surfer8400's Avatar
surfer8400
i installed the kill switch today and it works, thanks for the help
