H.p ?
Old Feb 23, 2004 | 07:54 PM
WALJON's Avatar
WALJON
H.p ?
I am putting a cam in a older 351w rebuild, from a 91 351w, the older one is a 70, the truck is all EFI , what kinda HP will this thing have ? will it be the same as the 91 engine that came out ? thanks
Old Feb 24, 2004 | 09:09 AM
daerhldgs2's Avatar
daerhldgs2
what heads are you using and what intake and exhaust?
Old Feb 24, 2004 | 04:50 PM
WALJON's Avatar
WALJON
I am using exhaust manifolds from stock 91,upper and lower Intakes too but the rest is all 1970
Old Feb 24, 2004 | 05:56 PM
Jimbo302's Avatar
Jimbo302
With a combo consisting of missmatched stock stuff and unknown aftermarket stuff like a spec-less camshaft, I doubt you can get a close estimate. Why not get it dynoed if you are worried?
Old Feb 24, 2004 | 06:13 PM
daerhldgs2's Avatar
daerhldgs2
your 1970 heads probably have larger valves and smaller combustion chambers which are a good combo for more power.
Old Feb 24, 2004 | 11:51 PM
WALJON's Avatar
WALJON
thanks daerhldgs2
Old Feb 25, 2004 | 07:24 AM
ferguson777's Avatar
ferguson777
Early 351Ws (up to approx. 73) had a taller deck height than the later ones. I would think you'd get a sloppy fit putting the later heads and intake on the early block.....i.e. poor fit of intake to heads....i.e. leakage.....
Old Feb 25, 2004 | 08:50 AM
daerhldgs2's Avatar
daerhldgs2
The taller deck height wouldn't affect the intake fit although it might require longer pushrods.
